snapped my first shaft! question?..
Old Oct 8, 2006 | 09:22 AM
GSR4U2NV's Avatar
Default snapped my first shaft! question?..
while launching at the track yesterday my driveshaft snapped on the passenger side....my question is should i not still be able to drive the car since i have a quiafe LSD. reason im asking is because i couldnt drive it after it snapped...but i still see the passenger side driveshaft spinning when i put it in gear. or does the passenger side driveshaft have to be fully intact to in turn spin the driverside shaft?
Old Oct 8, 2006 | 02:38 PM
GSR4U2NV's Avatar
Default Re: snapped my first shaft! question?.. (GSR4U2NV)
anyone??
Old Oct 8, 2006 | 04:12 PM
Bense's Avatar
don't drive it. that's 100% of driveline force on one wheel and 0% force on the non existant. Hope the LSD doesn't break.
but then again quaife will probably still replace it.
Get it towed.
Old Oct 8, 2006 | 05:38 PM
GSR4U2NV's Avatar
Default Re: (Bense)
i did get it towed.. but today i went to see if i could actually drive it with the one broken axle and it wouldnt move when i put the car in gear and released the clutch. isn' the car supposed to be drivable still if only one axle breaks and you have a LSD?
Old Oct 8, 2006 | 09:16 PM
integ401's Avatar
Default Re: (GSR4U2NV)
it's supposed to. my coworker snapped one of his axles on his itr and it just putted it home
Old Oct 9, 2006 | 07:03 AM
eddie_ek's Avatar
I have never tried it but I belive you cant drive the car with one axle beacuse LSD is a limited slip were it engages both tires under load and dissengages one tire when making a turn if you had a spool then you could possibly drive the car with one axle
NoXqcsMotosport
Transmission & Drivetrain
Aug 11, 2013 02:11 AM
jep
Jun 12, 2006 02:55 PM
kelvinchau25
Aug 20, 2004 05:24 AM
servion
Jul 1, 2003 11:59 AM
chrisJ
May 7, 2003 03:02 PM
