Smoke came out when I pulled the spark plug...
Old Jun 4, 2002 | 11:28 AM
JBet's Avatar
Default Smoke came out when I pulled the spark plug...
I was checking my spark plugs because my car has been bogging pretty bad below 4000 rpms, and when I pulled the #3 plug, smoke came out. Any ideas what would cause that. All the other plugs were fine.
Old Jun 4, 2002 | 11:33 AM
sgT's Avatar
sgT
Default Re: Smoke came out when I pulled the spark plug... (JBet)
smoke or steam?
if its steam chances are water is getting into the cylinder which means blown gasket.
Old Jun 4, 2002 | 11:40 AM
JBet's Avatar
Default Re: Smoke came out when I pulled the spark plug... (sgT)
I assume it was smoke, but I really don't know. I will do a compression test to see about the head gasket. But what does it mean if it is smoke?
Old Jun 4, 2002 | 01:08 PM
erniecars's Avatar
maybe some oil leaked into the spark plug hole from the gasket between the valve cover and the head and started burning off. If there was enough leakage from the head gasket to make steam you would notice other problems like smoke from your tail pipe
Old Jun 4, 2002 | 03:11 PM
Jared's Avatar
Default Re: Smoke came out when I pulled the spark plug... (erniecars)
burning oil maybe? damn that #3 honda cylinder.
Old Jun 4, 2002 | 06:10 PM
earl's Avatar
If the car was bogging bad, it may be excess fuel venting in a fog. Look for bad plug, wire, leaking injector or compression problem in that cylinder.
Old Jun 5, 2002 | 04:12 AM
JBet's Avatar
Default Re: Smoke came out when I pulled the spark plug... (earl)
Thanks guys I am going to try and do a compression test this weekend.
phaphon
24
Apr 13, 2017 09:00 AM
jc95148
Jan 9, 2013 04:11 PM
nengx07
20
Feb 6, 2009 08:10 PM
pinoyboy204
Apr 23, 2008 09:00 AM
ShagginJet
12
Aug 21, 2003 10:13 AM
