Skunk2 Throttlebody
Old Feb 18, 2006 | 08:59 PM
MenaceL.A.671's Avatar
Default Skunk2 Throttlebody
i have a skunk2 throttlebody 68mm brand new from my friend. i put it on my car.. and when i started the car...the idle is hella low (750rpm) and once the car gets hot the idle goes up.. is this normal??
Old Feb 18, 2006 | 11:21 PM
88crx's Avatar
Default Re: Skunk2 Throttlebody (MenaceL.A.671)
i just put one on my car today too and it seemed to idle around there too but didnt go up when car was warmer also is ur gas pedal super tight now??
Old Feb 19, 2006 | 12:51 AM
ondahush's Avatar
750 rpm when idling is normal you might have something else going on cuz i know mine juumps up when the car is warm but i have a vacuum leak have you tried adjusting you IACV not to sure if that could be the problem i would take it to a shop if your worried about it but i dont think you should 750 is norman range for idling
Old Feb 19, 2006 | 05:19 AM
Default Re: (ondahush)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ondahush &raquo;</TD></TR><TR><TD CLASS="quote">750 rpm when idling is normal you might have something else going on cuz i know mine juumps up when the car is warm but i have a vacuum leak have you tried adjusting you IACV not to sure if that could be the problem i would take it to a shop if your worried about it but i dont think you should 750 is norman range for idling </TD></TR></TABLE>
well cold start its on 750rpm... and usually with my stock bored (62mm)throttlebody.. its like 1500rpm cold start and goes down to 800rpm once its warmed up...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crx &raquo;</TD></TR><TR><TD CLASS="quote">i just put one on my car today too and it seemed to idle around there too but didnt go up when car was warmer also is ur gas pedal super tight now??
at first it got stuck.. so what i did was polish the throttlebody wit mothers.. and it didnt get stuck... but yeah my idle was so low and usually my cold start idle is high and once its warm it goes down.. but this time its low.. i even tried messing with the idle but still low and i also adjust the gold screw but still the same.. i think its normal... o well... what yall think&gt;??
Old Feb 19, 2006 | 09:48 AM
civicstar's Avatar
Default Re: (MenaceL.A.671)
from what ive been through with it, that seems to be the normal idle, at first, when the car is warming up with the iacv, it was around 1500 and then when it was warm, it dropped, i tried adjusting the idle screw but didnt change much so i decided to just tighten the throttle cable until the idle i wanted
Old Feb 19, 2006 | 10:09 PM
Default Re: (civicstar)
solid.. dayum today it was idling 715rpm.. but when it was warmed out it went up to 850 ooh well.. any sugguestion???
Old Feb 20, 2006 | 02:25 AM
ondahush's Avatar
you good just as long its not up passed 1krpm your good to go i wouldnt worry about idling at 850
Old Feb 20, 2006 | 03:56 AM
yea but cold start today was 715rpm...
Old Feb 20, 2006 | 05:23 AM
ondahush's Avatar
yea when my motor is cold it idles real low for a few seconds or so its normal as i know i dont think its nothing to worry about right when you start it up it idles real low for a few secinds then it jumps up in the RPM right more of an high idle then it evens out when the motor is warmed up? it should be nothing to worry about
Old Feb 20, 2006 | 11:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ondahush &raquo;</TD></TR><TR><TD CLASS="quote">yea when my motor is cold it idles real low for a few seconds or so its normal as i know i dont think its nothing to worry about right when you start it up it idles real low for a few secinds then it jumps up in the RPM right more of an high idle then it evens out when the motor is warmed up? it should be nothing to worry about </TD></TR></TABLE>
thanks man..!
ken2830
Nov 16, 2011 04:50 PM
w0ng_sta
Aug 31, 2006 02:25 PM
importdude2000
Mar 12, 2006 04:48 PM
Br1anPham
Feb 2, 2004 05:29 PM
