skunk 2 cam install ?
Old Jul 10, 2003 | 09:59 AM
stupidfast's Avatar
Default skunk 2 cam install ?
Does anyone have the instructions on how to degree stage one skunk cams?
Old Jul 10, 2003 | 11:12 AM
romeo619romeo's Avatar
Default Re: skunk 2 cam install ? (stupidfast)
put it on tdc on the crank.. take the valve cover off.. then the oil rails and cam caps ,mark the timing belt with the camgears with white out .. to make sure you replace it and put it in the same spot.. remove the cam gears off the old cams. then reverse the install.. make sure you have the motor cold.. as in let it sit over night or so.. and also buy a helms book .. it will tell you everything.. make sure you gather the tools you need...it should be.. 14 socket, wrachet, 10 socket,12 socket, feel gauge, valve adjustment tool, and a torque wrench, 8 socket, that should be all of it ..
note: i dont kno the exact torque specs on the bolts... i think its 9 pounds on the 10 bolts and 19 on the 12 bolts
Old Jul 10, 2003 | 11:14 AM
eg6h8k's Avatar
Default Re: skunk 2 cam install ? (romeo619romeo)
http://www.c-speedracing.com/h...m.php
Old Jul 11, 2003 | 08:14 AM
stupidfast's Avatar
Default Re: skunk 2 cam install ? (eg6h8k)
after they are in do i have to degree them to get them back to zero on the crank
Old Jul 12, 2003 | 12:00 AM
irev210's Avatar
your cams are key'd, the cam gears only go on one way. Basicly allign the car to TDC, then just take off cam gears then put them on your skunks, and put them back in TDC. Dont forget to do a valvejob
http://www.c-speedracing.com will help you with both of those
Old Jul 12, 2003 | 07:19 AM
IN VTEC's Avatar
Did you get a spec sheet with the cams?
Old Jul 12, 2003 | 07:57 AM
10K2HVN's Avatar
Default Re: skunk 2 cam install ? (IN VTEC)
7 lbs on valvecover
5..1..3..7 <valvecover bolts
6..2..4..8
16 lbs on cam bolts
8 lbs on end bolts (bolts 11-14?)
13...9...5..1..3..7..11 <order for cam bolts
14..10..6..2..4..8..12 <each cam
Head Bolts:
taking off
3..5...9...7..1
2..6..10..8..4
make sure engine is cold and loosen at 1/3 turns in order til all bolts are loose to prevent warpage
putting on
..9..5..1..3..7
10..6..2..4..8
please correct me if im wrong.
Modified by 10K2HVN at 7:06 PM 7/12/2003
erikiksaz1
Feb 26, 2007 04:16 PM
nieva
Dec 6, 2003 08:41 PM
Chuji
Jul 6, 2003 06:16 PM
Fred n J_v2.0
Mar 15, 2003 04:36 PM
shingles
Dec 24, 2001 04:45 AM
