Simple Ign. Timing Question
Old Mar 23, 2005 | 05:21 PM
CrazyKoreanCrx's Avatar
Default Simple Ign. Timing Question
I have a mod. 89 honda crx hf with a gsr head witha b16a2 short block. I have the car runnin now and was wondering for the ignition timing. Do I set it at 15 degrees B/c I'm using a Chipped P-72 (obd-1) ecu on my car? Also note that I already did the obd-0 to obd-1 conversion already and I brought the car to a local shop to do check my timing. They check it and set it at 22 Degrees B/c I burn out and crack two of my valves. (which suxc) So once again do I set it at 15 degrees? (the number came from Acura)
<Thanks for reading>
Old Mar 23, 2005 | 09:10 PM
Default Re: Simple Ign. Timing Question (CrazyKoreanCrx)
Bump>?<
ScottF
Aug 5, 2013 08:58 AM
godruler
Feb 25, 2006 07:47 PM
CrazyKoreanCrx
Mar 24, 2005 03:19 AM
3gLudeH22A
Jan 11, 2003 06:58 PM
under_psi
Jul 9, 2001 11:16 AM
