Simple Ign. Timing Question
Old Mar 23, 2005 | 05:51 PM
CrazyKoreanCrx's Avatar
Default Simple Ign. Timing Question
I have a mod. 89 honda crx hf with a gsr head witha b16a2 short block. I have the car runnin now and was wondering for the ignition timing. Do I set it at 15 degrees B/c I'm using a Chipped P-72 (obd-1) ecu on my car? Also note that I already did the obd-0 to obd-1 conversion already and I brought the car to a local shop to do check my timing. They check it and set it at 22 Degrees B/c I burn out and crack two of my valves. (which suxc) So once again do I set it at 15 degrees? (the number came from Acura)
<Thanks for reading>
Old Mar 23, 2005 | 06:18 PM
del_orson's Avatar
Default Re: Simple Ign. Timing Question (CrazyKoreanCrx)
that is what i would set it to. sure that its not 16 degrees?
Old Mar 23, 2005 | 06:43 PM
Default Re: Simple Ign. Timing Question (del_orson)
I called acura and ask for the setting for a 94 integra gsr
Old Mar 23, 2005 | 09:09 PM
Bump>?<
Old Mar 23, 2005 | 09:14 PM
Sack Master's Avatar
Is that initial timing or total timing? My car is running 16 degrees initial timing and 31 degrees at 3k. 21 degrees base timing seems a little high to me. Especially on a car with a chipped ecu thats adding a couple more degrees of total advance. As long as there is no detonation you should be fine. But typically a car will run better on the top end with timing retarded a little bit.
Old Mar 24, 2005 | 03:19 AM
Default Re: Simple Ign. Timing Question (Sack Master)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master &raquo;</TD></TR><TR><TD CLASS="quote">Is that initial timing or total timing? My car is running 16 degrees initial timing and 31 degrees at 3k. 21 degrees base timing seems a little high to me. Especially on a car with a chipped ecu thats adding a couple more degrees of total advance. As long as there is no detonation you should be fine. But typically a car will run better on the top end with timing retarded a little bit.</TD></TR></TABLE>
I need to know initial timing and total timing. B/c my total timing is 22 degrees and my chip has a on/off switch.
Thanks
turbo-crx
May 18, 2008 02:13 PM
CrazyKoreanCrx
Mar 23, 2005 09:10 PM
93SSPHatch
Jan 19, 2003 11:32 AM
3gLudeH22A
Jan 11, 2003 06:58 PM
under_psi
Jul 9, 2001 11:16 AM
