shifting is hard
Old Apr 10, 2003 | 07:42 PM
blkbeast's Avatar
New User
Default shifting is hard
i have a 94 integra with about 85k on it. the clutch has never been replaced. anyway, after taking a long trip, i noticed that shifting got noticably harder. even putting the car in first was difficult. sometimes i would grind also. this happened with every gear, 1-5.
i'm guessing my clutch is going or my sychros are messed. i was going change the tranny fluid hoping that would solve the problem but i haven't had any time. i drove the car like this for about 1.5 months.
on the way home today, i stalled with the clutch fully depressed! i started the car again and my tranny shift's like butter now! wtf?? what's going on? also, sometimes at a stoplight, my car locks me out of any gear! if i shut off the car and turn in on again, everything's fine. any suggestions? i hope i'll just have to change the fluid. TIA
Old Apr 10, 2003 | 08:50 PM
HKJ's Avatar
HKJ
Default Re: shifting is hard (blkbeast)
i get all those problems too except for grinding 1-5. i haven't changed the tranny fluid either, i'm sure it's just the tranny fluid.
where do you live?
Old Apr 10, 2003 | 08:55 PM
Diego Boost's Avatar
Default Re: shifting is hard (HKJ)
Is your clutch engaging pretty far out? If your clutch is ok then I suggest a tranny service.
Old Apr 10, 2003 | 09:32 PM
tilt's Avatar
All gears grinding suddenly would point towards a clutch problem, not synchros.
I had the same symptoms, plus sometimes the clutch would shudder when engaging. A metal bracket on the clutch disc broke off and was spinning inside and causing me problems.
You should check the basics regardless though since they could be the problem as well... tranny fluid, leaking slave/master cylinder, bent linkage, etc.
Old Apr 11, 2003 | 07:06 PM
blkbeast's Avatar
New User
Default Re: shifting is hard (tilt)
thanks for all the replies i'll finally have a chance to check out the car on sunday. just picked up some honda mtf today and we'll see if that helps. i really hope i don't have to replace the clutch.
tilt, now that you mention it, my clutch also shudders when engaging. it happened maybe 3-4 times
HKJ, i'm in scarborough, but i have to commute downtown for work.
i'll let you guys know what happens
Old May 4, 2003 | 10:49 AM
thirdvector's Avatar
I am having really similar problems with my 95 Gsr. I have problems with all gears, and there is a shuddering under slow clutch engagement. However, from a standstill there is no problem going into first. In fact, the higher my revs, the harder it is to shift into gear. I have gotten in the habit of letting my revs die down before I put it into gear When I did not let the revs die during shifting, there was a metal-to-metal grind going to third from second, and going from fourth to fifth there was a rubbery "bumping" WTF! I just had my fluid changed last year (25K ago). So, perhaps it is time for a change, but the MTF should not produce the symptoms I am dealing with.
DC5Danny
Jan 21, 2008 08:36 AM
phoshizzle88
May 17, 2006 10:39 PM
andrewasf77
Jun 19, 2003 07:32 PM
machine4321
Jun 1, 2003 10:41 PM
blkbeast
May 4, 2003 02:06 PM
