shifter problems
Old Jan 6, 2014 | 08:37 AM
SilasEk9's Avatar
Default shifter problems
while in gear in my 99 dx it feels as if the gears want to pop out while acceleration. i can move the shifter quite a bit back in forth while its in gear too. not exactly sure what it is thats causing this, shifter bushing maybe?
Old Jan 6, 2014 | 06:18 PM
96_cd7's Avatar
Default Re: shifter problems
Check your shift cables that connect to your trans
And see if you still have the cotering pin on both of them
Old Jan 7, 2014 | 09:11 AM
SilasEk9's Avatar
sounds good, ill check that out. thanks for the suggestion.
Old Jan 7, 2014 | 09:18 AM
kyden's Avatar
there are no shift cables on it. it can be a combo of a few things. the bearing/bushing setup on the shifter itself, the plastic cage the ball part sits in, or the rubber mounts that holds that linkage to the car. motor mounts i would check as well.
Old Jan 10, 2014 | 07:38 AM
Aviator guy's Avatar
Replacement bushings are less than $15.
swizz977
19
Jun 12, 2011 08:31 PM
turbo-crx
Transmission & Drivetrain
Aug 26, 2009 05:21 AM
honda2ksi
Apr 15, 2009 08:52 PM
DOUBLExDEUCEx22
Oct 25, 2008 09:44 AM
jbscivichb92
Nov 18, 2004 01:03 PM
