Shifter assembly problems
Old Sep 3, 2006 | 07:13 PM
Hatchorama's Avatar
Default Shifter assembly problems
I put in a new shifter because the tip on my last one broke off, and this new one has lot's of play in any gear, and it vibrates and a really annoying rattling noise comes into the car now. Does anyone have suggestions on what to look for? I was looking around and I think it might be that there is no shift rod seal, and that may be why it's vibrating, but I am unsure. Thanks for any help or suggestions.
Old Sep 3, 2006 | 08:41 PM
ekb16's Avatar
bushings
Old Sep 4, 2006 | 08:43 PM
mahatma's Avatar
Default Re: Shifter assembly problems (Hatchorama)
if you replaced the shift linkage then definitely it's the universal joint (where the bitch pin is) near the transmission.....
if just the shifter....then are you sure you replaced all the bolts and that the part that bolts to the chassis is on tight?
Old Sep 8, 2006 | 02:07 PM
Hatchorama's Avatar
Yepp, all bolts are tight and how do the bushings help? I can also feel that there's a little play if I pull up on the shifter, would bushings help for that too? and where can I get them?
ERKK
Mar 7, 2009 09:25 AM
sickofitall1113
Apr 8, 2007 06:38 PM
sycamore
Aug 19, 2005 03:35 PM
Hcivic88
Aug 11, 2004 08:48 PM
Nothing.Special
Jul 8, 2004 08:23 PM
