shift linkage? problem rattle?
Old May 26, 2012 | 11:30 PM
civic92si's Avatar
Default shift linkage? problem rattle?
i think its the shifter...or shift linkage because the noise is coming from there.
please help.
http://www.youtube.com/watch?v=omRID...eature=g-all-u
Old May 26, 2012 | 11:50 PM
mouab18c1's Avatar
Default Re: shift linkage? problem rattle?
Jack the car up and check for loose bolts. Shift linkage itself has nothing to do with it.
Old May 28, 2012 | 09:35 AM
civic92si's Avatar
i ment the shfiter not shift linkage. i tighten up that bolt.. shake the shifter no rattle. i did find 2 loose motor mount *the back one* but i tighten it up and thought that was the problem so i took it for a spin after still rattle....maybe something internal? however it sound like its coming from the shifter...
http://www.youtube.com/watch?v=Z85dvpm56_k another clip of reving.//
Old May 28, 2012 | 09:38 PM
mouab18c1's Avatar
Bad catalytic converter
Old May 31, 2012 | 10:20 AM
civic92si's Avatar
waiting for my cat..hopefully its that..
Old May 31, 2012 | 10:22 AM
mouab18c1's Avatar
All you need to do is take it off and shake it. If there was anything loose in it you would know.
Old Jun 5, 2012 | 09:16 PM
civic92si's Avatar
its weld on..
BiGcAmBoDiAnSaUsAgE
Mar 23, 2007 10:56 PM
honda4674
Jun 24, 2006 12:45 AM
loclowd
Oct 10, 2005 02:02 PM
loclowd
Oct 10, 2005 11:40 AM
aeon
May 6, 2004 09:36 PM
