HeLp!! SHIFT LINKAGE!!!
Old Mar 14, 2007 | 09:32 AM
BiGcAmBoDiAnSaUsAgE's Avatar
Default HeLp!! SHIFT LINKAGE!!!
here is my problem... when i put it in gear it still feel like its in neutural... how do i fix it?
Old Mar 17, 2007 | 09:28 PM
civicstar's Avatar
Default Re: HeLp!! SHIFT LINKAGE!!! (BiGcAmBoDiAnSaUsAgE)
that pin on the shift linkage? or maybe its on backwards
Old Mar 18, 2007 | 02:43 AM
98_Coupe's Avatar
The answer is:
d) not enough information
Old Mar 20, 2007 | 07:39 PM
Stephdavis18's Avatar
get under your car and I gurantee your missing the bushing (much like a washer) that goes between the shift linkage and the botom of your shifter....whoever took the shifter off at one point did not but it back on...I had or should I say have this same problem...washers will do the trick just make sure there the right size....
Old Mar 23, 2007 | 10:56 PM
fastredhatch's Avatar
are you talking about the one that goes on both sides of the shifter itself, next to the bearings/
Jay_Mills
Jan 4, 2013 01:30 PM
UrVtecIsLoud
Jul 26, 2006 07:26 PM
SeaBass
Jul 9, 2003 10:25 PM
lsvtec101
May 2, 2003 08:17 AM
