shift light ?
Old Jan 9, 2002 | 07:21 PM
arcboy's Avatar
New User
Default shift light ?
I want to take a shift light from a monster tach and place somewhere in the console or modify the cigarette lighter for space.
The question is can I get jus the shift light?
How can I wire the light to the stock tack (EX tack in my VX w/B18C) and have the light work at the correct shift point (8200).
Old Jan 9, 2002 | 10:41 PM
l's Avatar
l
Default Re: shift light ? (lowdiscrew)
personally i think its lame...
but you might want to do this... i heard there is a way to wire your check engine light to your tach so when you wanted to shift the check engine light would come on working as a shift light...
how it knows when to illuminate?? beats me? any one else?
Old Jan 9, 2002 | 10:44 PM
HybridEF9's Avatar
Default Re: shift light ? (IM ALL SHO)
That is true.......Only available when you use Hondata Stage 2......pretty cool added feature.......when you set your shift point......the check engine light goes on.........or you can wire a HD directional LED that comes in the kit.........check out hondata.com for details......
Old Jan 10, 2002 | 03:04 AM
Mista Bone's Avatar
D Tranny Guru
Autometer makes a shift light that uses rpm chips.
$64
To get the signal wire, easiest to goto master cylinder area and look for the factory servoce connector. It is a lone blue wire with a plug on the end. Usually wrapped/taped to the main harness.
[Modified by Mista Bone, 7:06 AM 1/10/2002]
Old Jan 10, 2002 | 05:59 PM
RenoRacing's Avatar
Default Re: shift light ? (Mista Bone)
or you can buy a cheap msd rpm activated switch and either a module selector or a set of pills as shown above and simply wire that up to turn on any light you want, even just a tiny l.e.d. that's what i had, it'd lite up my cluster area in my old gti. check ebay for some cheap rpm activated switches, sometimes called window switches also.
tscook3
Audio / Security / Video
Mar 13, 2012 05:58 PM
chrisfromsrq
Jul 27, 2009 01:20 PM
ANVIL
May 15, 2004 08:14 AM
IntegraVtecRaceR
Feb 29, 2004 06:01 PM
civicmark
Jul 5, 2002 03:06 PM
