Shaking steering wheel!!!!
Old Jan 27, 2003 | 12:57 PM
CereaLand's Avatar
Default Shaking steering wheel!!!!
when i hit 65+m.p.h. on my 98 civic the steering wheel shakes like ****... Can anyone help me?
Old Jan 27, 2003 | 01:42 PM
kyle h.'s Avatar
Default Re: Shaking steering wheel!!!! (civic504)
some cars just do that. older ones expecially. its like a point where the wheel just shakes up towards 50-70. maybe im wrong tho. does it do it after 65 at all?
Old Jan 27, 2003 | 01:51 PM
976's Avatar
976
New User
Default Re: Shaking steering wheel!!!! (kyle h.)
Balance your tires.
You wheel are not hub centric.
Rack and pinion steering once old does that.
Need an alignment...
... All of em'.
Old Jan 27, 2003 | 03:22 PM
sslude's Avatar
Default Re: Shaking steering wheel!!!! (w00t!)
if you are turning left to right then it could be torque steer. but get an alignment and chrck tire pressure
Old Jan 27, 2003 | 03:40 PM
Crisgo's Avatar
Default Re: Shaking steering wheel!!!! (sslude)
could also be a front tire thats tire belts split, check it out
Old Jan 27, 2003 | 03:45 PM
genetsang's Avatar
Default Re: Shaking steering wheel!!!! (Crisgo)
same thing happened to me.... took it to the shop to get it check and they said it was my brake rotor..... they changed it.. and everything was A oK
Old Jan 27, 2003 | 05:14 PM
CereaLand's Avatar
IT shakes at 65 and up. THanks for all ur help
Old Jan 27, 2003 | 05:38 PM
tominos's Avatar
wheel balance problem.
Old Jan 27, 2003 | 06:11 PM
Jerry's Avatar
i have the same problem w/ my 93 hatch. it does it around 80 mph. i think it is my steering column bearing. i can not find anything loose in my frony end. i've balanced my tires plenty of times still no good. when i go over bumps slow it sounds like crap. i've lived w/ it so far.
Old Jan 28, 2003 | 08:38 AM
genetsang's Avatar
Default Re: Shaking steering wheel!!!! (Jerry)
everytime i turn the steering wheel to the L or R, it sqeaks.......... could it be the powerstearing? or just something loose..... its louder inside the car, then the outside........
Old Jan 28, 2003 | 12:45 PM
XxDemonxX's Avatar
Default Re: Shaking steering wheel!!!! (genetsang)
my car shakes at around 80-90 but when im flooring it it doesnt. I live out in the desert so i am always in cruise at about 80 but there right some cars just do do it.i hav the same year and everything. my old accord was the same was but it was a 97
Old Feb 11, 2003 | 09:36 PM
buckfittyone's Avatar
same thing with my car,also when i hit bumps it squeaks anyone know what thats about?
Old Feb 12, 2003 | 08:05 PM
Default Re: Shaking steering wheel!!!! (buckfittyone)
Old Feb 12, 2003 | 08:26 PM
miahmouse's Avatar
I have a friend that's a bouncer at a local club, his arms are friggin huge ... he could probably hold the wheel still for ya
There's obviously a mouse stuck somewhere in your suspension. get a really mean cat and turn it loose ..... problem solved
Sorry, couldn't resist on me ..... Seriously though, the shaking is probably balance/alignment/hub centering (everything said before). For the squeaking, make sure everything is tight and or not rubbing..... after that I'd just go to town w/ a can of spray silicone and if it still didn't go away I'd just live with it and crank up the radio..
JDM C.A.R
Apr 5, 2011 06:17 AM
95C0upe
18
Oct 28, 2008 06:30 PM
pbizzlegsr
Mar 7, 2007 06:19 PM
dc2gsr96
Nov 6, 2006 08:26 PM
JoeDeMango
Mar 7, 2006 02:34 PM
