Setting Timing. Need Help ASAP!!
Old Jul 1, 2007 | 07:12 PM
95TYPEGSR's Avatar
Default Setting Timing. Need Help ASAP!!
ok everyone ive got a problem and anyone who can help out please please do so. Ok so my friend blew the motor on his 97 prelude h22a4 i believe. we bought the new motor and installed it and of course forgot to put the timing belt on while it was out of the car. We are having a serious problem setting the timing and getting the belt on. To start we found one line on the crank pulley we assume is the timing notch but cant find anything on the plastic cover that even resembles a timing mark. weve tried everything possible to get the belt up over the cam gears and were having no luck. if anyone could list the process from step one of setting it to tdc and finishing with the belt on properly timed would be awesome. or any advice you can shoot my way id appreciate. thankls
Old Jul 1, 2007 | 07:54 PM
atlplayer4life90's Avatar
Default Re: Setting Timing. Need Help ASAP!! (95TYPEGSR)
if im not mistaken correct me if im wrong but there should be a notch on the block it self not on the plastic
Old Jul 1, 2007 | 08:11 PM
95TYPEGSR's Avatar
ya theres no need to correct you on that. i just found out the notch is on the block instead of the plastic. I swear my teg is so much easier when it comes to this crap. but hey thanks for the reply. i appreciate it. you wouldnt happen to know how i would go about getting the belt to loosen up enough to get it onto the gears would you. the tensioner isnt seeming to be doing much. thanx
Old Jul 1, 2007 | 08:37 PM
its a hydro filled tensioner u have to use a special compressor tool then it will be loose enogh to move around
Evan Cronin
Aug 1, 2015 04:29 PM
crxabi
Feb 28, 2010 11:28 AM
skata89
Dec 30, 2006 06:48 PM
P1mpSlap
Jan 7, 2004 10:50 PM
dreweg
Jul 14, 2003 10:33 AM
