S2000 head on a k20 block?
Old Oct 10, 2005 | 06:49 PM
HomeDepotMade's Avatar
Default S2000 head on a k20 block?
so yeah i been reading around on some other website and i came across this topic. they said that the head gasket fits perfect with the k20. so in theory can they be put together. and it can i wonder what kind of power it'll make. ahaha well tech/mic did say engine theory.
Old Oct 11, 2005 | 06:27 AM
drdisco69's Avatar
Default Re: S2000 head on a k20 block? (Hype Vtec)
I've seen them both side by side and the similarities are striking. I believe the S2000 was a test bed for the K series head. Someone must have an idea as to whether they will work.
Old Oct 11, 2005 | 11:13 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: S2000 head on a k20 block? (drdisco69)
to preface this, i have no idea about the newer engine except what i have seen in pictures.
but i have seen in some s2000 pics that the cams are gear driven. there is no timing belt as far as i could see.. i dont know if the k20 is also like that or if it has a belt i have no idea at all. but just to throw that out there.
Old Oct 11, 2005 | 12:17 PM
Default Re: S2000 head on a k20 block? (sanimalp)
i wonder if the vtec head are similar. and yeah i heard that the S2000 engine was the cousin of the k-series. so thats really interesting
Old Oct 11, 2005 | 02:47 PM
Project Y's Avatar
I am very intrigued. Someone with a little more knowledge please step up!
Old Oct 11, 2005 | 03:07 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanimalp &raquo;</TD></TR><TR><TD CLASS="quote">
but i have seen in some s2000 pics that the cams are gear driven. there is no timing belt as far as i could see.. i dont know if the k20 is also like that or if it has a belt i have no idea at all. but just to throw that out there. </TD></TR></TABLE>
They're both chain driven.
Old Oct 11, 2005 | 03:14 PM
gsrious's Avatar
this idea has been covered before.
Old Oct 11, 2005 | 03:22 PM
Chiovnidca's Avatar
Default Re: (gsrious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrious &raquo;</TD></TR><TR><TD CLASS="quote">this idea has been covered before.</TD></TR></TABLE>
Go on......
Old Nov 2, 2005 | 01:48 PM
Default Re: (Chiovnidca)
and where is the information now?
Old Nov 2, 2005 | 09:41 PM
compwc18's Avatar
Default Re: (Hype Vtec)
I had actually searched this one day, and there is a topic here on HT that says that the heads are different, and they do not mount up but it didnt sound like he was really sure... What I think needs to happen is somebody to actually try this and make it work probably put out some nice numbers, then I'd be forced to go K-Series hehe....
Please somebody else shine some light on this topic... A lot of us would love to know....
Old Nov 3, 2005 | 04:04 PM
Default Re: (compwc18)
ahah for reals is someone has the money out there or works in a good motor shop ahah can someone do it. ahha.
Old Nov 3, 2005 | 04:41 PM
xerox445's Avatar
Do both engines spin the same way tho...?
Old Nov 3, 2005 | 08:38 PM
Slow ass EF's Avatar
Default Re: (xerox445)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xerox445 &raquo;</TD></TR><TR><TD CLASS="quote">Do both engines spin the same way tho...?</TD></TR></TABLE>
good point
Old Nov 3, 2005 | 08:44 PM
MidShipCivic's Avatar
They dont spin the same direction.
Old Nov 3, 2005 | 09:49 PM
compwc18's Avatar
Default Re: (MidShipCivic)
so since they don't spin the same direction its not possible to mount the head on the block? how is it they spin different directions??? Sorry if thats a dumb question, I dont know much bout the s2k motors or the RSX motors.....
Old Nov 3, 2005 | 10:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by compwc18 &raquo;</TD></TR><TR><TD CLASS="quote">so since they don't spin the same direction its not possible to mount the head on the block? how is it they spin different directions??? Sorry if thats a dumb question, I dont know much bout the s2k motors or the RSX motors..... </TD></TR></TABLE>
You can spin the cam backards. when you want to think about things you arent sure that match up make a list of things that you can try for trying to fit it on there.
1. Buy a gasket see if F-series and S2k are similar buy placing it on the deck.
2. Compare combustion chambers.
3. See if bore spacing the same.
Old Nov 3, 2005 | 10:09 PM
xerox445's Avatar
Im pretty shure if you spin a cam backwards, your valvetrain is going to be in a world of hurt, very fast.... ramp angles come to mind....
Old Nov 3, 2005 | 11:43 PM
compwc18's Avatar
Alright I understand where you guys are coming from, thanks for the quick answer....
Old Nov 3, 2005 | 11:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xerox445 &raquo;</TD></TR><TR><TD CLASS="quote">Im pretty shure if you spin a cam backwards, your valvetrain is going to be in a world of hurt, very fast.... ramp angles come to mind....</TD></TR></TABLE>
No dont spin counter-clockwise cams clock-wise.
Completely new cams must be made.
Production car engines in marine use are made to spin backwards they have ''marine cams and stuff'' .
Old Nov 4, 2005 | 12:17 AM
compwc18's Avatar
so then your theory is they both spin the same.... lol, or am i understanding this wrong?
Old Nov 4, 2005 | 12:29 AM
BaNAnABoAt689's Avatar
B A N N E D
From: los angeles, Eagle Rock, CA, united states of america
anyway you can't cause changing chain to belt aint gonna happen...
Old Nov 4, 2005 | 01:53 AM
Default Re: (BaNAnABoAt689)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BaNAnABoAt689 &raquo;</TD></TR><TR><TD CLASS="quote">anyway you can't cause changing chain to belt aint gonna happen...</TD></TR></TABLE>
Are you saying that the s2k is a belt cam gear driven? If so your're wrong.
Old Nov 4, 2005 | 07:50 PM
B A N N E D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidShipCivic &raquo;</TD></TR><TR><TD CLASS="quote">
Are you saying that the s2k is a belt cam gear driven? If so your're wrong.</TD></TR></TABLE>
my bad your right.. seems to be all the new motors are all chains these days.
Old Nov 4, 2005 | 09:17 PM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
the cam trigger plates and the length of cams present an issue,, they would have to be custom cams. ive never seen the blocks but i have both heads here.
the S2k rocker assembly looks like it would fit the K24 but there are no LMA bosses in the K24. the valve arrangements are the same from what i can tell.
Old Nov 5, 2005 | 09:45 AM
Default Re: (mike_belben@yahoo.com)
wow this is so helpful in answering my queston.
