S-AFC problems.....MAP sensor voltage too high.
Old Mar 15, 2003 | 10:58 AM
.RTErnie's Avatar
Default S-AFC problems.....MAP sensor voltage too high.
Well I've had this problem for a while now....here it goes. Well...I have the throttle setting pointing up, set for a 4 banger, map sensor 5in 5out, and everything works.....but It throws a cel. I checked the wiring 5 times and had other people check the wiring . Its all right. I just dunno. The map signal going into the afc is around 4.2v and when it comes out of the afc to the pcm it is around 6.4v . I dont know why its doing this, if you have ANY ideas let me know please. Also I think it may be due to an over lap of the TB on the AIS hole on the intake manifold....but it didn't do it before I had the afc so like I said before.....dunno
Thanks in advance
Eric
Old Mar 15, 2003 | 11:58 AM
non-VTEC's Avatar
Default Re: S-AFC problems.....MAP sensor voltage too high. (RTErnie)
i thought for all honda's the S-AFC map sensor setting was 6 in and 6 out.
i dont think that will fix your problem though.........maybe your MAP sensor is bad?
Old Mar 15, 2003 | 01:10 PM
.RTErnie's Avatar
Default Re: S-AFC problems.....MAP sensor voltage too high. (non-VTEC)
forgot to add...its a neon I'll try changing the map sensot tomorrow
Acidcrakker
Engine Management and Tuning
Oct 10, 2010 12:05 PM
xxstuntin4life
Nov 21, 2009 06:16 PM
Boosted Chemist
Jun 15, 2005 02:30 PM
