map sensor wiring (using one map sensor for two devises.)
Old Jun 10, 2005 | 07:27 PM
Boosted Chemist's Avatar
Default map sensor wiring (using one map sensor for two devises.)
I got the 3.5 bar mapsensor that came with my zietronix wideband. Can I T in the map sensor line for my ecu into this sensor and not mess up the voltage readings or sensor readings.
Old Jun 11, 2005 | 02:30 AM
Default Re: map sensor wiring (Boosted Chemist)
come on guys no input?
Old Jun 15, 2005 | 01:53 PM
no body wants to say anything about this topic? i think if the ecu and the display read the same map sensor everything will be ok, i just want to verify this
Old Jun 15, 2005 | 02:30 PM
dustin's Avatar
it should be fine. try it
cleanazcoupe
Jul 1, 2009 07:53 PM
methos713
Jun 11, 2007 12:43 PM
