Running Rich at Idle and Lean at WOT
Old Sep 15, 2005 | 10:44 AM
vtecb20coupe's Avatar
B A N N E D
Default Running Rich at Idle and Lean at WOT
i'm working on a car that's running very rich at idle and stoich at regular cruising speeds. but if you give it gas or are at wot, it's showing to be running very lean. what are the different possible reasons? here's short list of the parts on the vehicle that may be the culprit.
ls/vtec
p28 w/jun program
walbro 255
obd0 b16a injectors
the fuel filter is brand new. so i know that is not the issue. it wasn't doing this before but is now all of a sudden. could it be an o2 sensor, bad injector?
any ideas are appreciated.
Old Sep 15, 2005 | 11:32 AM
Buzzbomb's Avatar
Default Re: Running Rich at Idle and Lean at WOT (vtecb20coupe)
How lean and rich is it running? What does the wideband show?
Are b16 injectors correct for an lsvtec? I'm asking because I don't know and it seems too small. Wouldn't you want at least gsr injectors? Hell they could be the same cc as far as I know.
Anyway, the problem is probably just in the program.
Old Sep 15, 2005 | 02:08 PM
B A N N E D
i would not know about the injectors. i assumed that all b series vtec injectors sprayed the same.
Old Sep 17, 2005 | 09:38 AM
B A N N E D
anyone?
Old Sep 17, 2005 | 11:42 AM
v4lu3s's Avatar
RTFM
most liekly it is the "jun" program.
tune it so the fuel demands are being met properly.
Old Sep 17, 2005 | 07:04 PM
B A N N E D
Default Re: (v4lu3s)
ok, so the program can just go bad all of a sudden? reason i ask is because the same ecu was used on my last motor without any issues.
Old Sep 17, 2005 | 07:57 PM
v4lu3s's Avatar
RTFM
so it worked on yoyr last engine, but this is a new engine is it not?
Old Sep 17, 2005 | 09:06 PM
veggiemaster's Avatar
have you pulled the plugs? you can check if you have a cylinder that is leaning out, also, it may be just an issue of tuning it.
Old Sep 18, 2005 | 02:21 PM
B A N N E D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">so it worked on yoyr last engine, but this is a new engine is it not? </TD></TR></TABLE>
yes, completely different motor.
Old Sep 18, 2005 | 02:22 PM
B A N N E D
Default Re: (veggiemaster)
i'll pull the plugs again and do another compression check, if need be.
Old Sep 18, 2005 | 03:09 PM
rainforest's Avatar
Default Re: (vtecb20coupe)
jun chip and a walboro 255. thats your issue. do you have a adjustable fpr if you do adjust if not its time to get one becaue that pump will simply (sometimes) overpower the fpr. it sound like too much fuel pressure at idle check the fuel pressure and you will most likly see your answer.
Old Sep 18, 2005 | 03:21 PM
v4lu3s's Avatar
RTFM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb20coupe &raquo;</TD></TR><TR><TD CLASS="quote">yes, completely different motor.</TD></TR></TABLE>
i personally would not expect one program to work on every engine.
i have an h22 program that i made for acustoemr who was able to run a 13.3 in the 1/4 mile, but for me its way too lean up top. for a friend of mine its not even possible to drive with it. when i switched my program up i saw a .4 second gain at the track...and we all have h22's with bolt ons.
Old Sep 18, 2005 | 07:08 PM
mmuller's Avatar
Mad Scientist
so..what are the wideband readings?
all those ''jun,etc'' fuel maps are usually way rich for most applications; timing could be an issue, but then again most of those generic chips use stock timing.
Old Sep 19, 2005 | 05:21 AM
B A N N E D
Default Re: (rainforest)
yes, there is a fpr on there. unfortunately, the pressure has been pegged at like 48 psi. i was thinking of swapping fuel pumps to see if that helps the issue.
civicracer1997
Apr 18, 2012 10:37 AM
DispicableB
Mar 29, 2012 12:29 PM
be18see1
Engine Management and Tuning
13
May 28, 2011 05:42 PM
D_TY3
Aug 4, 2007 05:42 AM
AllMotorDA9
22
Mar 7, 2005 11:17 AM
