Got a BAD Radiator Fluid leak, need help
Old Sep 17, 2005 | 05:19 PM
Shizznaz's Avatar
Default Got a BAD Radiator Fluid leak, need help
I have NO idea where this leak is coming from. I recently had the top end rebuilt and I used all brand new gaskets and everything. I been driving it around just fine for the past few weeks but some buddies of mine pointed out that I had a leak of some sort when I left a meet last night.
So heres some pictures of what im seeing. When I took them, the car had been running for about 2 or 3 minutes. I did refill the radiator and the catch can before I started the car and the engine was cool. This is a B18c1 and the water drips were exactly where the pullys are, as you can see, theres a droplette on the pully itself after I turned the engine off.
Old Sep 17, 2005 | 06:16 PM
mmuller's Avatar
Mad Scientist
Default Re: Got a BAD Radiator Fluid leak, need help (Shizznaz)
its comming out of your water pump, it took a dookie
Old Sep 17, 2005 | 06:37 PM
Shizznaz's Avatar
Default Re: Got a BAD Radiator Fluid leak, need help (mmuller)
I never touched that thing too.. How would that go bad?? is it easy to replace?
Old Sep 17, 2005 | 06:40 PM
Shizznaz's Avatar
oh,
And where is this water pump located? If im looking down on the engine in front of the car
Old Sep 17, 2005 | 07:45 PM
b18bEKcoupe's Avatar
It is behind the timing belt cover. Its a PITA when the motor is in the car. If you havent replaced your timing belt this would be a good time because it has to be removed to get to the water pump.
Old Sep 18, 2005 | 09:05 AM
Shizznaz's Avatar
Default Re: Got a BAD Radiator Fluid leak, need help (b18bEKcoupe)
Old Sep 18, 2005 | 01:48 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shizznaz &raquo;</TD></TR><TR><TD CLASS="quote">oh,
And where is this water pump located? </TD></TR></TABLE>
Straight up from where the waters dripping.
Old Sep 18, 2005 | 08:23 PM
Shizznaz's Avatar
Default Re: Got a BAD Radiator Fluid leak, need help (Chiovnidca)
haha yea. I havent touched that part of the engine yet but will be good to take a look
Old Sep 19, 2005 | 06:37 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shizznaz &raquo;</TD></TR><TR><TD CLASS="quote">And where is this water pump located?</TD></TR></TABLE>Your avatar looks like a GSR, so lets pretend that's what you have??
Look at the lower timing cover, near where the #18 bolts go. It's under that round part of the cover. You have to remove the timing belt to get the pump, so get a new timing belt while you're at it.
The round opening for the pump is in the upper-right part of the block in this picture.
zcmotor
Aug 17, 2008 07:23 AM
88sleeperx
Jan 1, 2007 07:01 AM
skata89
Oct 2, 2005 04:38 PM
garados
Jun 9, 2002 02:41 PM
