Running leaner at idle?
Old Apr 28, 2009 | 03:07 PM
accord_raffi's Avatar
Default Running leaner at idle?
So I used to run lean all around after a few months from when my build started so I put in Walbro 255 about 2-3 months ago. My idle afr's were right on 14.7 for the first time and I was holding the stock fuel pressure at WOT much better which gave me richer afrs. I was happy. The other day I got some new wheels and just before putting them on I did a little burnout to get celebrate the removal of steelies. Now I'm not saying this was the cause, but I noticed the idle afr's immediately after went to the 16/17 range. It would go to 15 once in a while but would keep going back to 16's. Under load, things seem "okay." The numbers are close to the same for the most part. I noticed though that the fuel pump got a little bit louder when I would do two clicks on the ignition to prime it. Also, I noticed today after driving, 2 clicks would pressurize, and my fans would come on (hopefully, those came on just b/c my car was still hot). Anyways, anyone think the louder fuel pump may be the reason my idle afr's went lean?
Old Apr 28, 2009 | 03:55 PM
mmuller's Avatar
Mad Scientist
Default Re: Running leaner at idle?
what kind of injectors? ecu setup?
Old Apr 28, 2009 | 06:17 PM
dsm 450cc's and tuned on Crome
Old Apr 29, 2009 | 07:33 AM
brunch time bump
Old Apr 29, 2009 | 07:53 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
the walbro is way louder than the stock fuel pump. so there's your answer to that..
and how long have you been using your wideband? have u run any race gas through it? or just pump? was it calibrated before using?..
Old Apr 29, 2009 | 07:59 AM
Lol I was waiting for someone to say "walbro's are loud." Yes, I know they're loud, but it has gotten louder. As for my UEGO, from what I understand, they are not able to be re-calibrated. I installed a new sensor as of September b/c my older one got dinged by a good ole rock and it failed.
Old Apr 29, 2009 | 01:15 PM
I know the little plastic stud/tab that uses the retaining clip to hold the pump's filter on broke before the install. I asked about it on here and a lot of people said the filter would still hold on there fine. They had the same issues and nothing happened to them. If somehow my filter fell off, do you think that could be my issue? It's still fine during normal driving which is why I assumed that wasn't the reason.
Old Apr 29, 2009 | 10:05 PM
very early morning bump
Old Apr 30, 2009 | 10:51 AM
92_civic's Avatar
clogged up fuel filter?
is the pump only louder on the second prime?
Old Apr 30, 2009 | 05:32 PM
fuel filter is nearly brand new.
Old May 4, 2009 | 11:23 PM
so anyone else thinking if the sock filter fell off the pump, it just wouldn't run?
Old May 6, 2009 | 10:06 AM
92_civic's Avatar
I'm pretty sure the pump would still work if the sock fell off...unless the sock fell off and something from inside the tank (rust) plugged up the pump (doubt it)
how is your fuel pressure? regulator on its way out?
Ntense90crxsi
Dec 19, 2006 02:28 PM
freddy_hung
Aug 29, 2003 02:38 PM
GSRwBOOST
Jan 7, 2002 11:44 AM
