Rubber boot covering the b*tch pin
Old May 7, 2007 | 02:00 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Rubber boot covering the b*tch pin
On B- and D-series transmissions where the shift rod attaches to the transmission with that darned b!tch pin, there is a metal shaft that goes into the transmission case. Is there some sort of seal there that keeps fluid from coming out? I assume the rubber boot that covers that joint doesn't hold in fluid, because mine is torn completely into 2 pieces, but I don't see any evidence of fluid loss.
I will be ordering a new boot and b!tch pin this week. As of now, that shaft going into the tranny case is exposed when in 1st, 3rd, or 5th gears. That won't be a big problem, will it?
Also, anyone know where I can find an 8.5 mm punch? I'd like to make this job as painless as possible. Please don't suggest other tools I can use. I have tried all kinds of other tools and they're always a PITA. I'd like to actually use an 8.5mm punch like the Helms manual shows. I checked at Sears but I don't believe they had one in that size.
Old May 7, 2007 | 02:34 PM
base-op.1320's Avatar
Default Re: Rubber boot covering the b*tch pin (PatrickGSR94)
Get a 1/4" roll pin punch - it is like a normal non tapered punch but it has a ball on the end that fits inside the roll pin so it can't walk around while hitting it - I got mine from snap-on - I don't understand what your question is about the gear selection shaft but it sounds to be working normal.
Old May 7, 2007 | 04:53 PM
Community Builder
I'm just making sure that it won't be a problem having that shaft exposed for awhile since the rubber boot that normally covers it is completely torn in 2 pieces.
Old May 7, 2007 | 06:34 PM
non-VTEC's Avatar
Default Re: (PatrickGSR94)
i think that rubber boot/seal thing is just to keep dirt/water away from the pin so it does not rust/corrode.
Old May 7, 2007 | 07:16 PM
Legion's Avatar
* B A N N E D *
Default Re: (non-VTEC)
The boot just keeps it from rusting. I have a trans sitting in my garage right now that was missing the boot for a long period of time and the linkage is SEVERELY rusted.
Old May 7, 2007 | 07:25 PM
stumpyf4's Avatar
http://www.amazon.com/Schley-H...r=8-2
Schley tool should make it the easiest it's gonna be with the tranny in the car.
Old May 7, 2007 | 07:35 PM
Community Builder
Default Re: Rubber boot covering the b*tch pin (stumpyf4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stumpyf4 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.amazon.com/Schley-H...r=8-2
Schley tool should make it the easiest it's gonna be with the tranny in the car.</TD></TR></TABLE>
oh nice, I think I'll pick up one of those
Bird333
Jun 19, 2008 07:01 PM
blackeg
May 14, 2008 09:06 PM
turbotime
May 27, 2006 02:27 PM
masterx
Aug 19, 2004 07:13 PM
X2BOARD
May 10, 2003 09:29 PM
