Rod bearings....
Old Jan 16, 2006 | 09:54 PM
StylishDOHC's Avatar
Default Rod bearings....
Yes iv'e searched...basically I just want to roll in some new bearings, the motor is out of the car and on an engine stand..How do i figure out which rod bearings to use? The one iv'e pulled off so far looks like it has a brown marking on it, but I can't tell for sure so i want to confirm it.I don't have access to micro-meter's etc, I understand there is some sort of code to determine which ones to use?
Old Jan 17, 2006 | 04:21 AM
v4lu3s's Avatar
RTFM
you rad teh numbers on teh rods, crank and block and then use the chart in the helm manual to determine waht size (color) bearings you need
Old Jan 17, 2006 | 08:40 PM
Default Re: Rod bearings.... (StylishDOHC)
i cant figure out where any of the numbers are though...?
Old Jan 18, 2006 | 05:44 AM
Rukusmasta2's Avatar
Default Re: (v4lu3s)
numbers are on the crank...search because i just did this like 3 weeks ago...or go buy a helms or something, this has been covered mad times
Quetzolcotl
Feb 17, 2017 02:50 AM
russ.shafer
Nov 6, 2011 06:46 PM
92sihbk
Aug 8, 2007 10:40 AM
aldong
Apr 27, 2005 10:29 PM
InfamousRS
Feb 8, 2002 12:13 PM
