rich idle problem
Old Jan 2, 2011 | 11:54 PM
zerotorquecrix's Avatar
Icon2 rich idle problem
i swapped a b18b into my crx and installed a wideband af ratio gauge. after installing an ecu that was "tuned" for my setup i noticed that it was idling at full lean and would richen as i pressed the gas it almost died a few times because of this. i put in some sea foam (didn't know at the time that it was bad for widebands) and now it is idling rich at 10:1 and will lean out to 13/14:1 as i press the gas. fuel pressure seemed to drop ~4 psi since it idled lean so don't know if the regulator diaphragm has a hole or if the sea foam cleaned out my injectors a little too well. any ideas.
Old Jan 3, 2011 | 08:18 AM
mouab18c1's Avatar
Default Re: rich idle problem
Apparently you need a tune.
I'm assuming that you have an ecu with a tune for some similar build to yours? Right?
Old Jan 3, 2011 | 12:57 PM
yes exactly. but it ran lean and now suddenly is running rich. the tune didn't just change itself up
mikeunreal2
29
Mar 22, 2006 06:26 PM
Burke
Jul 24, 2003 01:14 PM
97hb
Mar 21, 2002 09:19 PM
97hb
Mar 21, 2002 09:13 PM
97hb
Mar 21, 2002 07:02 PM
