ITR Dual spring height/thickness
I have a set of ITR dual springs the paint is gone on all the springs. I have 8 springs that are short and the coil is thick. I have 8 that are taller and with thinner coils. I am looking to find out which spring goes where? Does the taller and thinner ones go on the intake and hte shorter thicker go one exhaust or the other way around. I have googled but unable to come up with and for sure answers..
Thanks
Russ
Thanks
Russ
which ever fits in side the other. the taller ones should fit around the shorter ones, or was it the other way around(don't remember)? but for sure you pair them up, short with tall. not matching height.
found a pic, only took like a min. should look like this.
http://www.octanemotorsports.com/p22...duct_info.html
Let me rephrase.. I have 8 outer springs that are short and thick and 8 outer springs that are taller and thiner coils. I am asking (as seen in the pic) which spring goes where.. The taller ones go on intake or exhaust?
Double check me but im pretty sure the blue is for the intake and the yellow is for exhaust.
I see a little blue paint in the pic, so maybe some of the others might have a trace?
juniordc2
Suspension & Brakes
May 8, 2005 01:50 PM
