Revs bounce while warming up.
When the car is cold and I'm just sitting there idling the revs will slowly move from 1k to 2k, getting slower as the car warms. When the car is hot it doesn't happen. Any ideas? Seems like something simple.
I've cleaned my IACV after replacing with a known-good piece and the car sort-of does this...
It idles fine until it's reaching the warm zone, and then the revs will bounce from 700-1000 repeatedly and slowly until it's fully warmed up. I don't think it's the IACV in my case unless I did a bad cleaning job somehow
If that does not work either, then try taking off the plate on the bottom part of the throttle body, and tightening the fast idle screw. The screw most likely vibrated loose and causes that if it's not the IACV.
HTH.
HTH.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">If that does not work either, then try taking off the plate on the bottom part of the throttle body, and tightening the fast idle screw. The screw most likely vibrated loose and causes that if it's not the IACV.
HTH.</TD></TR></TABLE>
I agree, the first thing I would check is the FITV... If not that then it could be something electronic but i doubt it (TPS voltage over 0.45vdc at idle, bad oxygen sensor, etc.) Good Luck
2 bolts to get the IACV off, took the rubber gasket out (didnt want brake cleaner on it), sprayed some brake cleaner on a shop towel, rubbed the filter/grille with the shop towel, car idles perfectly!
My friend Mike (jdmDXrex) is running an auto P28 on his '88 Rex via a nonOBD-OBD1 jumper that I made... His idle had been acting up ever since we swapped heads and went OBD1... I hadn't really gotten any time to take a close look at what was making the revs bounce but last night I finally got a chance to change the auto/manual selection to straight manual... Well I did that and now the car idles perfect so it wasn't any problem in my jumper or oxygen sensor wiring as I suspected... All you have to do is open up the ECU... desolder out the RP17 and RP18 resistors then put a jumper in for RP18... If you are unsure of where RP17/18 are look right next to your ROM you'll also see (RP3/4/5/6/7/8/13/14)... If you need anything else let me know... Peace
bonta-kun
13
Mar 14, 2011 08:02 AM
jxhxb
Sep 22, 2010 11:17 PM
