Reverse Problem
Old Jan 29, 2006 | 05:56 PM
Mr_Moos's Avatar
Default Reverse Problem
So when i put it in reverse i have to hold it there or it will kick me out why would it do that??? 99 ls tranny
Old Jan 29, 2006 | 06:05 PM
old man neri's Avatar
Default Re: Reverse Problem (Mr_Moos)
cause it's not all the way in or your tranny is going to go soon.
When shiting into reverse you must do this first
1) come to a complete stop
2) shift into another gear, proably first
3) keep the clutch in the whole time
4) then shift into reverse calmly and cleanly.
5) Now let the clutch up and back up with out running over your neighbours cat.
Reverse doesn't have a syncro so you must use the syncro of another gear to stop the lay shaft from spinning.
Cheers.
Old Jan 30, 2006 | 10:08 PM
Mr_Moos's Avatar
Default Re: Reverse Problem (old man neri)
um no aint that simple
Old Jan 30, 2006 | 11:10 PM
ekb16's Avatar
does it pop out of 5th too?
Old Jan 31, 2006 | 04:12 PM
Mr_Moos's Avatar
Default Re: (ekb16)
no 5th is fine just reverse it goes in it for like 3 seconds then pops out ?????
Old Jan 31, 2006 | 04:59 PM
smokey2.0's Avatar
Default Re: (Mr_Moos)
check your transmission oil, if it pops out of R it will start to pop out of 5th real soon!
Old Jan 31, 2006 | 11:19 PM
Mr_Moos's Avatar
Default Re: (smokey2.0)
why would 5th have anything to do w/ reverse????
Old Feb 1, 2006 | 12:30 AM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_Moos &raquo;</TD></TR><TR><TD CLASS="quote">why would 5th have anything to do w/ reverse????</TD></TR></TABLE>simple the transmission has three shift forks, one for 1/2, another for 3/4, and one last one for 5/R. so if R is popping out, 5th will follow! it could also be a shift fork problem, as it might be wearing on one side more than the other! i hope i make sence
Mmmeecho
10
Jul 28, 2008 09:06 PM
envision
Feb 16, 2008 09:21 PM
URtaxes
Dec 18, 2005 03:35 PM
Pretty Hot And Tuned
Jul 27, 2005 06:57 PM
99turboeg
Jun 5, 2005 01:42 PM
