rev limit
Old Feb 24, 2009 | 09:40 PM
2ndchirp's Avatar
Default rev limit
just put an f22b from a 95 accord in my friends 90 accord and used old engine harness.. the ca runs and idles weird and it wont go over 2,000 rpms.. does anyone have any idea wat can cause this... we switched the ecu's but that did not help
Old Feb 24, 2009 | 10:16 PM
jwicecold's Avatar
Default Re: rev limit
Did you start the other engine before installing it, or was it already pulled??
Old Feb 25, 2009 | 12:45 PM
Remiss's Avatar
is it the dohc f22b?
Old Feb 25, 2009 | 04:09 PM
2ndchirp's Avatar
no the motor was already pulled... and its a single cam...i thinkk it has somethin do with the distributor but all the plugs are just fine... and i dont kno wat can cause it to have a rev limit
Old Feb 25, 2009 | 07:03 PM
2ndchirp's Avatar
Old Feb 25, 2009 | 07:25 PM
Vtec9778's Avatar
are either of the engines vtec and are the connections ok?
Old Feb 26, 2009 | 04:08 AM
Remiss's Avatar
well the only thing to my knowledge that will cause a rev limiter is the ecu...either it is in limp mode or there is a bad connection
Old Feb 26, 2009 | 07:05 PM
2ndchirp's Avatar
The f22 that we put in is vtec and the ecu for the engine came with it... we tried 3 different ecu's and all had the same issue...could a sensor possibly cause this?
Old Feb 26, 2009 | 07:20 PM
GhostAccord's Avatar
Out of those three ECU's have you tried to retrieve any Diagnostic Trouble Codes? See if maybe a fault somewhere in the PGM-FI system might be causing the problem?
Old Feb 26, 2009 | 07:25 PM
Targa250R's Avatar
be professional
So how exactly did you manage to plug an OBD-1 VTEC ECU into a pre-OBD wiring harness?
Old Feb 26, 2009 | 11:30 PM
Peeonu25's Avatar
90-96 accords are obd1 f22's
Old Feb 26, 2009 | 11:33 PM
Peeonu25's Avatar
anyways, check if you have any CEL's. check your grounds. make sure your MAP or TPS sensors are swapped.
Old Feb 27, 2009 | 03:18 AM
Targa250R's Avatar
be professional
Um, no. Are you dense?
'92-95 Accords are OBD-1. '90-91 is pre-OBD and '96+ is OBD-2. VTEC is '94+ only.
So explain to me how this guy plugged his '90 Accord engine harness into a '95 Accord VTEC ECU.
Jesse Johnson
Acura TSX
Mar 31, 2016 10:59 AM
accordbob
Nov 30, 2011 10:01 PM
E.
May 8, 2008 05:13 PM
halfcard
May 4, 2007 07:02 PM
