retap or heli-coil
Old Jan 27, 2006 | 09:19 AM
gsrious's Avatar
Default retap or heli-coil
i was just wondering what would be best in my scenario...
the spark plug hole is not stripped all the way. there is a middle section in the thread in which the threads are stripped out, but other than that the threads are fine.
*for example, starting from the top of the head the threads are fine... then going into the middle of the head the threads are stripped out(just 2 or 3 threads), and then going in closer to the combustion chamber the threads are fine.
should i just retap it or should i heli-coil the thing?
kindof like this... http://justatv.com/pages/heli_...l.htm
*btw, this is on a gsr head. i would like to keep the consistency(sp) of the material to the same as possible to prevent any different materials from expanding at different rates(if you know what i mean).
Modified by gsrious at 10:45 AM 1/27/2006
Modified by gsrious at 10:47 AM 1/27/2006
Old Jan 27, 2006 | 10:51 AM
onepoint6i's Avatar
Default Re: retap or heli-coil (gsrious)
re-tap it....take it to someone with experience..it'll be ok..
Old Jan 27, 2006 | 08:51 PM
EnzoSpeed's Avatar
Default Re: retap or heli-coil (onepoint6i)
Well definitely re-tapping is where you want to start. Especially since the beginning of the threads are still good and there is no risk of cross-threading.
I honestly wouldn't heli-coil it. You'd be surprised how much a tap can fix up ruined threads. I tapped an o2 bung that was so horribly fucked up that you couldn't even tell it was ever threaded. After the tap, good as new.
F4nunez
Honda Civic (2001 - 2005)
Jun 18, 2019 06:33 PM
Ross Lauger
Dec 27, 2011 07:15 PM
Tim2179
Apr 24, 2009 08:16 AM
RACEPAK
Oct 23, 2008 10:08 PM
Nikolai
Nov 14, 2002 05:19 AM
