Results on compression test
Old Apr 14, 2005 | 05:51 PM
crxvtecturbo's Avatar
* B A N N E D *
Default Results on compression test
i just did a compression test here are the results
1# 180
2# 165
3# 180
4# 178
i think cylinder 2 i s a little low it is a 9.1 motor could i use that engine restore stuff or get a valve job to bring that cylinder up
Old Apr 14, 2005 | 09:37 PM
Kendall's Avatar
It's obvious it's not a head gasket problem. Next time you do a compression test, after you test #2, pour a bit of oil into it and retest it, if it goes up then it's a ring problem, if it doesn't, it's a valve problem.
Old Apr 15, 2005 | 05:59 AM
* B A N N E D *
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">It's obvious it's not a head gasket problem. Next time you do a compression test, after you test #2, pour a bit of oil into it and retest it, if it goes up then it's a ring problem, if it doesn't, it's a valve problem.</TD></TR></TABLE>
i tried the oil trickit did not go up do you think i need valve adjustment
Old Apr 15, 2005 | 08:23 AM
* B A N N E D *
Default Re: (crxvtecturbo)
TTT
Old Apr 15, 2005 | 10:18 AM
asubennett's Avatar
It's possible you have that one cylinder too tight on the valve lash. Adjust your lash and repeat. Worth a shot before you go pulling the head for a valve job.
Old Apr 18, 2005 | 08:51 AM
* B A N N E D *
Default Re: (asubennett)
ttt
hutcho3
Apr 11, 2011 06:54 PM
Dave_Dc2
Mar 21, 2008 05:35 PM
JFG Kevin
Jul 19, 2006 07:49 PM
crxvtecturbo
Apr 18, 2005 01:48 PM
the.hamburglar
May 7, 2004 07:00 PM
