ATTENTION: those running test pipes...
Old Apr 18, 2005 | 05:20 AM
Iceman05's Avatar
Default ATTENTION: those running test pipes...
Has anyone had problems with a test pipe causing the primary O2 sensor to become saturated? Im running the AFC hack and recently fouled an O2 sensor after installing a test pipe. I dont know if it's related or not, just wanted to see if anyone else had this problem. I was thinking maybe it's due to less backpressure and therefore causes the car to run too rich. Thanks in advance for your info.
Old Apr 18, 2005 | 07:59 AM
95lstegman's Avatar
Default Re: ATTENTION: those running test pipes... (Iceman05)
if you run an aftermarket exhaust w/ stock cat, have your car tuned, then put in a test-pipe, you'll need to get it retuned. i went from stock straight to testpipe w/ bigger exhaust, and didn't have to have it redone. BTW, i didn't retune immediately after putting a 2.5" cat in. it was basically the same as no cat, but a little cleaner and cost $50 for the 49-states cat.
BTW, your oxygen sensor will foul from running too rich. get a fuel tuner already and fix your problems.
Old Apr 18, 2005 | 08:00 AM
kndaqikEG's Avatar
No, it is most likely due to a poor tune on your V-afc. Not having a cat wont do anything to the upstream O2 sensor.
Old Apr 18, 2005 | 08:52 AM
Iceman05's Avatar
the tune on the afc is great, i just think the O2 sensor went bad cuz it was old
the rook
Oct 20, 2015 08:00 PM
Raven_Accord
Jul 23, 2007 03:54 PM
RealAce
Aug 17, 2006 05:48 AM
Sohc-Vtec
26
Jan 13, 2003 10:58 PM
blktyper2001
Sep 10, 2001 07:56 AM
