compression test results on 9.1 motor
Old Apr 13, 2005 | 05:51 PM
crxvtecturbo's Avatar
* B A N N E D *
Default compression test results on 9.1 motor
i just did a compression test here are the results
1# 180
2# 165
3# 180
4# 178
i put a cap of oil in the low cylinder and it did not raise it i wanted to see if you guys would suggest me to get a valve job to bring that one cylinder up but if it was a valve job would it tap or not?
Old Apr 13, 2005 | 06:21 PM
J337_UNIT's Avatar
Default Re: compression test results on 9.1 motor (crxvtecturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxvtecturbo &raquo;</TD></TR><TR><TD CLASS="quote">i just did a compression test here are the results
1# 180
2# 165
3# 180
4# 178
i put a cap of oil in the low cylinder and it did not raise it i wanted to see if you guys would suggest me to get a valve job to bring that one cylinder up but if it was a valve job would it tap or not?</TD></TR></TABLE>
A valve job may not help at all, because it could be that the rings on the pistons are worn. 180 for 9:1 CR motor is normal. The 165 on the number 2 cylender isnt TOO big a difference to lose sleep over. if it was like 100 then i would say you got a problem there.
Old Apr 13, 2005 | 06:34 PM
blackeg's Avatar
Default Re: compression test results on 9.1 motor (J337_UNIT)
overall your #'s are within spec for a 9:1 static compression motor. i just wonder if a capful of oil was a lil too much...(not like it would really hurt anything)
Old Apr 14, 2005 | 03:44 AM
* B A N N E D *
Default Re: compression test results on 9.1 motor (blackeg)
ttt
Old Apr 14, 2005 | 04:14 AM
ginoboy1978's Avatar
Numbers look alright to me.
Old Apr 14, 2005 | 06:26 AM
nojoke's Avatar
My 9:1 compression motor had numbers of 180 all around...
If you can, you should do a leakdown test. That will be a better indicator of how your motor is doing.
Old Apr 14, 2005 | 07:00 AM
adseguy's Avatar
Default Re: (nojoke)
That's pretty much the compression i have on my motor right now. I am boosted and have zero blow by and everything is fine. IMHO those numbers are just fine and i wouldn't worry about anything.
BTW the oil trick only works on blown rings and ringlands and i really don't think you have that.
Old Apr 14, 2005 | 07:49 AM
nonvtecD's Avatar
Numbers look fine to me, have you done a leakdown on the motor?
Old Apr 14, 2005 | 08:34 AM
* B A N N E D *
Default Re: (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">That's pretty much the compression i have on my motor right now. I am boosted and have zero blow by and everything is fine. IMHO those numbers are just fine and i wouldn't worry about anything.
BTW the oil trick only works on blown rings and ringlands and i really don't think you have that. </TD></TR></TABLE>
so what do you think it is than valve job?
Old Apr 14, 2005 | 03:58 PM
* B A N N E D *
Default Re: (crxvtecturbo)
ttt
Old Apr 14, 2005 | 04:05 PM
dustin's Avatar
looks fine
Old Apr 14, 2005 | 04:23 PM
* B A N N E D *
Default Re: compression test results on 9.1 motor (dustin)
will i lose anymore compression or will it affect my horsepower can i try that engine restore just to bring that one cylinder up
Modified by crxvtecturbo at 5:41 PM 4/14/2005
dustin's Avatar
I wouldn't worry about it
Old Apr 14, 2005 | 04:31 PM
boostmywankle's Avatar
my motor with 9:1 arias had 185-190 psi all across..i wouldnt worrie about it!
Old Apr 14, 2005 | 04:43 PM
* B A N N E D *
Default Re: compression test results on 9.1 motor (96teggyls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96teggyls &raquo;</TD></TR><TR><TD CLASS="quote">my motor with 9:1 arias had 185-190 psi all across..i wouldnt worrie about it!</TD></TR></TABLE>
the key answer is yours is across and mine is like 180 in 3 cylinders and 165 in the fourth one
Old Apr 14, 2005 | 04:47 PM
dustin's Avatar
it's close enough though.
Old Apr 14, 2005 | 04:51 PM
* B A N N E D *
do you know if i can use that engine restore to bring that one cylinder up
dustin's Avatar
is this a fresh rebuild?
Old Apr 14, 2005 | 04:54 PM
* B A N N E D *
no
Old Apr 14, 2005 | 04:56 PM
dustin's Avatar
Oh, I really wouldn't worry about it then. Just boost it.. hehe
Old Apr 14, 2005 | 04:59 PM
* B A N N E D *
will that cylinder take a beating and get any worse?
Old Apr 14, 2005 | 05:01 PM
dustin's Avatar
Should be fine
Old Apr 14, 2005 | 05:10 PM
adseguy's Avatar
it'll be fine!!!! Dustin had to say this like 8 times! I've been boosting for 7 months hard now and I have lower overall numbers then you...that one cylinder just has a little more blow by.....it's nothing remotely severe
Old Apr 14, 2005 | 05:13 PM
dustin's Avatar
Default Re: compression test results on 9.1 motor (adseguy)
I only had to say it 5 times, quit exaggerating hehe
Old Apr 14, 2005 | 05:16 PM
* B A N N E D *
well i just want to make sure it is ok i am taking it back for tuning and dont want no problems with it
