reset ecu?
Old Mar 23, 2006 | 01:44 PM
BigECivic's Avatar
Default reset ecu?
i just bought a bomz cai and was wonderin how exactly to reset my ecu so it will "learn" of my new intake, thanks
Old Mar 23, 2006 | 02:41 PM
JDMtype Eg6's Avatar
to restart the ecu have the car at full operation temp. turn off the car and take out the battery ground wire (or take out 7.5 backup fuse under the hood for hondas) for 5 mins. Put it back in place, start the car without touching anything electrical and let it sit for 5 more mins. Then turn the car off
Im not sure if this really helps, but i also do it everytime I install something. Can anyone clarify if it really does help?
Old Mar 24, 2006 | 12:06 PM
Perfectionist's Avatar
Default Re: (JDMtype Eg6)
AFAIK, the ECU sort of constantly retunes things. Removing the back up fuse resets any stored codes. Removing the battery ground totally rests the ECU to it's base parameters. If you do that, you must start the car with all electrical loads turned off, and let it idle without touching the throttle until the engine reaches operating temperature. That's the idle re-learn process.
Old Aug 8, 2011 | 04:12 PM
soco13's Avatar
Default Re: reset ecu?
hey guys i swaped a d15b7 on my 90 hatch but when i reach 15 it chokes and have to shift to 2 gear and it dose that 3,4 but when i reach 30 on 2 gear and 3 its when i reach 45mph what do u think it is. I think i have to do an idle relearn procedure.
Old Aug 8, 2011 | 05:52 PM
JDM-KIDD's Avatar
Is it misfiring?
Old Aug 9, 2011 | 04:32 PM
exb18c1's Avatar
You don't really need to reset the ECU.There is IAT sensor which reads the temperature changes.
Old Aug 9, 2011 | 05:13 PM
soco13's Avatar
Originally Posted by JDM-KIDD
Is it misfiring?
im not sure if its a misfire but it chokes. I changed the comp on the car to see if it would change anything and i put an 89 comp on my 90 civic and the car took longer to choke now it chokes at 22 1st, 30 2ed, 45 3ed. so idk if it needs a rest on the ecu. please help!!. thanks
ieatrice
Mar 16, 2004 12:48 PM
sonicblueteg2k
Apr 29, 2003 04:52 PM
Turbo Powa
11
Jun 2, 2002 09:20 AM
FroggyR
Mar 10, 2002 05:36 PM
illusion
Feb 18, 2002 03:02 PM
