Replacing valve seals... remove the head or not
Old Jun 2, 2003 | 09:05 PM
MisterB's Avatar
Default Replacing valve seals... remove the head or not
i am in need of new valve seals on my b16a since the machine shop messed up
the machine shop will replace them if i bring down the head but since i used new head bolts and a mugen head gasket i am hesitant to do so
i know it is possible to do on the car but how hard is it to do i know i will have to get valve spring compressor and valve seal remover...
any advice is great
Old Jun 3, 2003 | 07:32 AM
JimBlake's Avatar
Default Re: Replacing valve seals... remove the head or not (MisterB)
Usually you have to put compressed air into the sparkplug hole. Just like a leakdown test.
When you compress the valve springs & take out the keepers, you have to keep the valve from falling down into the cylinder. That's what the compressed air is for. If you lose the air pressure, the valve falls down & you have to pull the head.
I don't know if you can put the piston at TDC & just let the valve fall? When it rests on the piston, maybe its too low to get the keepers back on?? There must be a reason why people don't do it this way.
Old Jun 3, 2003 | 07:40 AM
IN VTEC's Avatar
Default Re: Replacing valve seals... remove the head or not (JimBlake)
The valve seals can hold up the valves as long as you don't push down on them. You need the compressed air if you remove the seals.
Old Jun 3, 2003 | 07:49 AM
1_bad_EF's Avatar
headbolts arent bad after one torqing. use once more again and get another head gasket. pull it off.
Old Jun 3, 2003 | 09:26 AM
adrian1281's Avatar
maybe some rope in the cylinder to keep the valves up?
Old Jun 4, 2003 | 03:51 PM
MisterB's Avatar
Default Re: (sparky69)
anyone know of good tools or part numbers to do the seals with head on the car?
Old Jun 4, 2003 | 05:05 PM
93LSivic's Avatar
Default Re: (MisterB)
A good tool to pull the old ones off with are snap-on spark plug wire pullers which are pliers with rounded ends. And to reinstall the seals a 10mm 12 point 1/4" socket with extension and a small hammer works awesome.
As stated above use compressed air in the cylinders.
Old Jun 4, 2003 | 07:18 PM
straightline's Avatar
yeah this way works better than compressed air and is better for the motor.
Old Jun 4, 2003 | 07:47 PM
MisterB's Avatar
Default Re: (straightline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by straightline &raquo;</TD></TR><TR><TD CLASS="quote">yeah this way works better than compressed air and is better for the motor.</TD></TR></TABLE>
what way works better
i have to keep the valve from falling into the cylinder so either compressed air or rope in the cylinder...
Old Jun 4, 2003 | 09:31 PM
real9999's Avatar
I tried using a KD spark plug puller to remove the seals. It was worthless. I just took the head to NAPA and they replaced the seals for a few bucks.
If you plan on keeping the head on, you'll need a rail type-valve spring compressor. Those don't come cheap.
Tom
mycrx7
Sep 22, 2005 08:03 PM
BigC-ivic
Oct 22, 2004 02:46 PM
biggie2005
Feb 26, 2004 06:23 PM
civicracer1993
Apr 6, 2003 01:01 PM
98Psi ITR
Dec 5, 2001 10:59 AM
