Replacing the timing belt
Old Aug 14, 2002 | 12:01 PM
Dokta's Avatar
Default Replacing the timing belt
I am replacing the timing belt on a B20Z. How am I supposed to line up the lines on the cam gears? What about the notch on the crank pulley? I assume its the same as the B18B. Any help is appreciated.
Old Aug 14, 2002 | 12:05 PM
95GS-R's Avatar
Default Re: Replacing the timing belt (Dokta)
From what I understand you need to rotate the crank pulley to get everything to line up. It is very important to only rotate it counter-clockwise (the direction of the engines natural rotation) ... although I am not sure why.
Once the crank mark is line up with the block TDC mark the cam gears should both have their arrows pointing straight up.
Old Aug 14, 2002 | 12:15 PM
Dokta's Avatar
Default Re: Replacing the timing belt (95GS-R)
which mark on the crank pulley is TDC? The white or the red? And what am I supposed to line that notch up with? Is there a mark on the block?
How do I know if the arrows on the cam gears are pointing straight up? Do I line up the lines on the sides of the cam gears with the head gasket?
Old Aug 14, 2002 | 01:37 PM
95GS-R's Avatar
Picture of timing marks is on the right.
As for the cam gears ... they have a mark that will point at each other when at TDC, measure that with a straight edge, and don't get off a tooth!
Old Aug 15, 2002 | 10:31 AM
Dokta's Avatar
Thank you very much. I need to get rid of my D16Z6 Helms manual and get one for my new B20Z or LS
foolsforever
11
Aug 9, 2018 05:08 PM
joeekrub
May 20, 2007 10:13 AM
RTW DC2R
May 23, 2005 10:33 AM
R.S.
Oct 11, 2004 03:12 PM
brockscivic
Jul 6, 2004 10:07 AM
