Timing Problems
Old May 20, 2007 | 08:12 AM
joeekrub's Avatar
Default Timing Problems
Okay.....We have the bottom pully mark alined with the mark on the front cover. The two arrows are pointing up on the cam pullys , the two marks on the edge of the cam pullys are also aligned. But.... the engine is locking on about a half turn or less. The cam belt is tight. Why is it locking?
Old May 20, 2007 | 08:36 AM
skata89's Avatar
What way are you rotating it?? Towards the front right?
Old May 20, 2007 | 09:10 AM
joeekrub's Avatar
it doesnt matter which way i turn it. all i did was put a water pump with a larger pully on it. I marked everything in red befor i took the belt off, now all the marks line up, but it still locks
Old May 20, 2007 | 10:13 AM
Sam92Teg's Avatar
Default Re: (joeekrub)
Did you remove the spark plugs, compression can sometimes be a bitch. And only rotate the crank pulley counter clockwise. And you are using the white line on the crank pulley to line up right?
94dxt
Oct 27, 2004 12:36 PM
R.S.
Oct 11, 2004 03:12 PM
brockscivic
Jul 6, 2004 10:07 AM
SC94DB8
Aug 23, 2002 04:24 PM
Dokta
Aug 15, 2002 10:31 AM
