cam duration?
Old Aug 14, 2002 | 05:26 PM
TurBoTeG's Avatar
Default cam duration?
ok im real confused about when crower or crane cams posts "advertised duration" and "duration @ .050" Can some explain this??
Old Aug 14, 2002 | 08:27 PM
TurBoTeG's Avatar
Default Re: cam duration? (TurBoTeG)
up
Old Aug 14, 2002 | 09:58 PM
earl's Avatar
OK, I'll try. Duration is the amount of degrees the valve is held open by the cam. It is actually hard to tell at exactly what degree # the cam starts to open. This is because of something called a clearance ramp which is ground in the cam to slowly lift the valve for the first few degrees.
In order to compare the usefull amount of duration in two different cams, duration is listed as beginning and ending at a certain lift. Some start the duration at .010" or 1mm or .020" or .040" or .050".
An example of measuring a cam might be..total duration at 0 lift of 280 degrees, .010 lift at 265 degrees and .050 lift have 250 degrees of duration.
Two cams could have 280 degrees of duration at 0 lift but one could have 250 degrees duration at .050 and the other only have 235 degrees at .050. The 250 lift would be the wilder of the two cams.
You can only compare duration between two different cam manufacturers by knowing at what lift the duration is measurered
Old Aug 15, 2002 | 03:09 AM
kinesistech's Avatar
Default Re: cam duration? (earl)
This is when a degree wheel comes into play. With it and a dial indicator, you measure it yourself. You can also find true tdc for the block and head. Then use your cam gear to dial in the cam.
I think one is good stuff.
Old Aug 15, 2002 | 08:00 AM
Mover's Avatar
In GENERAL , what have you guys found to be the difference in degrees when a cam is measured at .050" and 1mm. (Obviously it'll have more duration at 1mm than .050').
Old Aug 15, 2002 | 10:33 AM
earl's Avatar
Default Re: cam duration? (Mover)
1mm=.040, so degree diff between .040 and .050, depending on the rate of lift of the cam, would be between 5-10 degrees as an estimate.
harhoosh
Feb 10, 2012 10:20 PM
250r king
Mar 13, 2010 10:32 AM
HFP_racing
11
May 12, 2009 06:12 PM
Mover
Nov 19, 2002 06:40 PM
