replacing piston rings?
i have total seal piston rings in my high comp ls/vtec, do you think its worth it replacing it with oem rings? i have a 12:1 ls/vtec and my compression right now is 180,190,200,220.. the motor only has about 2000+ miles.. i was wondering if it was worth replacing them and if so would i need new rod and main bearings?
tia
tia
tia
tia
What cams are you running??? I would definately leakdown the motor before you start pulling it apart.... High lift/duration cams will drop the overall dynamic compression therefore reading low on the PSI.... Peace
i heard total seal will rob hp, i'm not buring any oil i will do a leak down test soon but i'm pretty sure its the rings.. i'm running skunk stage 2 cams, ive heard others running similar setups and getting 300+psi across the board!! so do you guys think thats really low for that setup?
I doubt you have would 300+psi across the board running SK2st2 cams.... Your static compression would have very very high to achieve this... Those cams generate a lot of overlap which intern bleeds off cylinder pressure... Peace
remember when doing a comp test its not in vtec
climb_on
16
Sep 5, 2007 08:49 PM
Sketch_hs
May 12, 2005 06:44 PM
