Cracked Ringland? Replace piston and rings ONLY??!
Old May 12, 2005 | 04:27 PM
Sketch_hs's Avatar
Default Cracked Ringland? Replace piston and rings ONLY??!
need your thoughts and opinions.
I don't really have the money or time to rebuild.
I was thinking about just throwing in a used piston and some new rings with out doing anything else to the motor.
I think #3 has cracked rings because the car is smoking blue, and #3 plug is black while all the others are fine. Haven't done a compression test but i can guess the results... no smoke from breather, car runs great just smokes... mostly when i let of after boosting then get back on the gas. Also smokes when i rev it at idle.
It's that or i'm maxing out the credit cards to buy a built block. what do you think?
Old May 12, 2005 | 04:53 PM
Sketch_hs's Avatar
Just did a comp. test
60psi
So can i just throw in a piston w/ new rings and call it a day?
this would just be untill i can afford to build it
Old May 12, 2005 | 05:00 PM
SpeedingHatch's Avatar
Default Re: (Sketch_hs)
tough choice, im in the same boat.
bump for some guidance for both of us
Old May 12, 2005 | 05:10 PM
Sketch_hs's Avatar
Default Re: (SpeedingHatch)
my engineer co-worker says:
"not the best idea, but cheap.... should be okay"
Old May 12, 2005 | 05:41 PM
Sketch_hs's Avatar
come on, some one has done this!
Old May 12, 2005 | 05:45 PM
_entropy's Avatar
Try and find a set of SRP's, we got a set localy for 250 bucks brand new with rings. It's some cheap insurance. Your way could probably work, but I'd re-ring and hone the whole motor.
Old May 12, 2005 | 05:52 PM
Blazin Civic's Avatar
Default Re: (Napoleon Dynamite)
Honestly if you are gonna go through all of that you might as well get some eagle rods too and have a pretty much fully built bottom end. Also did you check the sleeves to see if they need to be machined?
Old May 12, 2005 | 06:44 PM
Sketch_hs's Avatar
i found a 50,000 mile stock b16a complete bottem end for only $200!
guess i'll have a block with one bad piston for sale!
who has my headgasket?!
ZCHondaCRX91
Engine Machining & Assembly
Sep 14, 2015 04:23 PM
Metal Head
Feb 19, 2009 08:37 PM
ek9tl
Sep 21, 2007 03:52 PM
ck123
19
May 18, 2006 10:37 PM
bennyhonda7
Jun 8, 2005 04:02 PM
