low compression=bad piston rings
Old Aug 17, 2004 | 11:07 AM
skunk2eg's Avatar
Default low compression=bad piston rings
got low compression in 1 cylander in a b18b and did a leak down test and it brought it back up after adding oil. that would mean worn rings right?
should i just replace that 1 or replace the rings on all 4 cylanders? (the other 3 had ok compression)
Old Aug 17, 2004 | 12:10 PM
xEnderx's Avatar
Default Re: low compression=bad piston rings (skunk2eg)
If you already have the head off and you're goign to pull one of the rings, might as well do all of them.
ZCHondaCRX91
Engine Machining & Assembly
Sep 14, 2015 04:23 PM
PARADOX_sf
Jan 3, 2011 05:42 PM
lilo_goki
Feb 18, 2009 01:56 AM
honda305
10
Feb 15, 2009 06:34 PM
EJ8chu
Jun 16, 2008 05:26 PM
