Replacement Master Cylinder probelms
Old Jul 3, 2002 | 03:11 PM
delSolLS's Avatar
Default Replacement Master Cylinder probelms
After replacing my master cylinder with a new one from a parts house, I have more pedal travel. Brakes work, but I have to push alot farther than before.
Anyone have trouble with parts house MC's? Better to get the more expensive one from Honda?
This is a track lapping/daily driver with Goodridge SS brake lines, all new calipers and pads.
Old Jul 3, 2002 | 03:50 PM
Honda4CX-T's Avatar
Default Re: Replacement Master Cylinder probelms (delSolLS)
Bleed properly ??? Just a thought ?
Skip if already done ..... Next thing I cn think of you might of broken your master cylinder seal while bleeding brakes (too much pedal can make seal guve way)
Old Jul 3, 2002 | 06:32 PM
Chiovnidca's Avatar
If you bled all the air out of the system, it probably needs to have the rod length adjusted.
Old Jul 3, 2002 | 06:34 PM
MrBite's Avatar
Default Re: Replacement Master Cylinder probelms (Chiovnidca)
bingo! Key step to replacing any hydraulic parts
Old Jul 4, 2002 | 04:34 PM
delSolLS's Avatar
Rod length adjusted, bled like you can't believe. Here's a new symptom- pedal travel changes intermittantly. Sometimes firmer, sometimes real mushy.
Brake booster passes Helm's test.
Help!
Old Jul 4, 2002 | 06:33 PM
Chiovnidca's Avatar
Help!
That sounds like a bad master cylinder. Honda sells the best ones.
thecruzs2007@yahoo.com
Mar 20, 2010 03:52 PM
shadohconspiracy
13
Sep 27, 2007 10:09 PM
miataguy
Jul 8, 2003 09:00 PM
spork sport
Dec 7, 2002 10:54 AM
erniecars
Nov 18, 2002 12:41 PM
