To replace the Field vtec controller
Old Jun 3, 2003 | 06:36 PM
GokuSSJ4's Avatar
Default To replace the Field vtec controller
for the pass 3 years i have had fields vtec controller , which is ver easy to use .
but once in a while the back plug that goes in to the unit itself attends to get a bit loose and gives me problems . Should i replace it with Apexi controller and is it and easy thing to do . ???
Old Jun 3, 2003 | 08:59 PM
sslude's Avatar
Default Re: To replace the Field vtec controller (Spoon1)
ive always heard bad things about the fields Vtec controller. i'd recommend the VAFC for you. nice little toold if you tune it on a dyno
Old Jun 3, 2003 | 09:31 PM
ALLMOTOR18's Avatar
Default Re: To replace the Field vtec controller (sslude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sslude &raquo;</TD></TR><TR><TD CLASS="quote">ive always heard bad things about the fields Vtec controller. i'd recommend the VAFC for you. nice little toold if you tune it on a dyno</TD></TR></TABLE>
The VAFC is better than the Fields.. I used both and it seemed like the Fields never held its setting very long..
The VAFC good, and it isnt hard to use...
Old Jun 3, 2003 | 10:16 PM
GokuSSJ4's Avatar
Default Re: To replace the Field vtec controller (ALLMOTOR18)
im going to invest on it , i just got the car tuned . But i have no problem hitting the dyno again to tune the VAFC since im installing a BBK fuel pump to replace the stock one
Thanks
Old Jun 5, 2003 | 06:12 AM
Xsi's Avatar
Xsi
Go with the Apexi
If you want to stay with the SFC, you can cut the wiring plug off and solder straight onto the pins in the back of the unit. I had the wobbly plug problem and doing this fixed it.
EG2aGSR
Sep 23, 2006 02:04 PM
Revolemilbus
Jul 16, 2006 07:53 PM
devnull
Honda S2000
Jun 22, 2005 07:35 PM
LU
Sep 29, 2004 01:28 PM
Thrillhouse
Jun 17, 2002 04:01 PM
