Removing crank pulley
Old Jul 17, 2004 | 07:35 AM
weraider30's Avatar
Default Removing crank pulley
post if you have any insight on this. need asap, thanks.
Old Jul 17, 2004 | 08:40 AM
Kendall's Avatar
Use a really really really big air gun. You'll probably need at least a 1/2 inch drive air gun, or you can use a crank pulley tool that allows you to use a breaker bar to break it loose.
Old Jul 17, 2004 | 09:08 AM
weraider30's Avatar
Default Re: (Kendall)
i am using a 1/2 drive air gun, cranked it up to 130 psi, and it didn't budge, any other ideas?
Old Jul 17, 2004 | 09:19 AM
Kendall's Avatar
My 1/2 inch drive air gun wouldn't do it either. I finally ended up borrowing one from the shop next to us. It was considerably more powerful than mine (which maxed at 130 psi) and it zipped it right off.
Old Jul 17, 2004 | 10:21 AM
weraider30's Avatar
and when putting it back on any advice?
Old Jul 17, 2004 | 11:40 AM
accorse07's Avatar
Default Re: (weraider30)
130 psi should suffice to remove a crank pulley...go to 150 if you have a valve on the compressor.
as for putting it back on do it the same way you took it off.....
Old Jul 17, 2004 | 06:51 PM
weraider30's Avatar
Default Re: (accorse07)
borrowed a $150 pulley remover from a shop, using 2 breaker bars and 2 large adults later, it finally came off. thank for the help.
Old Jul 17, 2004 | 07:02 PM
hondaguyef's Avatar
IR's "thunder gun" has never let me down
Old Jul 17, 2004 | 07:17 PM
weraider30's Avatar
Default Re: (hondaguyef)
MAC tools has a tool that i used, you just use 2 1/2 sockets and 2 large breaker bars and 2 people. kinda pricey at $150
Old Jul 17, 2004 | 09:30 PM
SiDelSol97's Avatar
I used a floor jack handle as a huge breaker bar. 1 person and 2 seconds later, I had a loose crank pulley.
Old Jul 18, 2004 | 07:22 AM
weraider30's Avatar
Default Re: (SiDelSol97)
how did you keep the crank pulley from rotating?
Old Jul 18, 2004 | 12:06 PM
Cory man's Avatar
I bought the moroso pulley tool. My IR 1/2" drive impact takes em loose and the moroso tool helps me torque em down.
Old Jul 18, 2004 | 12:27 PM
weraider30's Avatar
Default Re: (Cory man)
so how and how much should i torque it down when putting back on?
jodyboy
13
Jul 1, 2012 11:52 AM
xxmastermindxx
Aug 22, 2006 09:22 PM
tdizz07
Feb 25, 2006 09:49 PM
flip1199
Nov 12, 2004 06:50 PM
.cingham
39
Apr 11, 2004 12:05 AM
