Removing crank pulley bolt with air impact gun - Still need the special hex tool?
I'm about to attempt to remove it, using an air wrench. Do I still need to use the special tool to hold the pulley in place?
http://www.oreillyauto.com/site/c/de...0717&ppt=C0374
Thanks
Thanks
Re: When removing crank pulley bolt...
You do not need the special tool to hold the crank pulley if you are using an air impact gun. The only one I have had success with is a 3/4 drive impact. I used an ingersoll rand but a blue-point, Mac or Snap on prolly just as good.
If you plan to use a 1/2 drive impact it is highly unlikely you will succeed if its the first time removing it. In which case if not using the 3/4 drive(or larger) impact then you will need the tool and a breaker bar and socket and long cheater bar (I've had to use a 6 footer) Just my .02 cents
It is a 1/2 impact wrench, says it delivers something like 360 ft-lbs of torque. Im just hoping I dont have to take the wheel off to use a breaker bar because, well I can't.
I was turning the crank pulley to get the cam pulley to tdc and suddenly there is a lot of resistance when i try to turn the crank pulley, I have a socket on it, I was waiting to get it to tdc to get the bolt off. Is that right?
Seagull Management
Yes that's normal, you're up against the compression stroke.
I was using a Husky it was rated 360 ft/lb. It didnt budge. All I heard was the sound of the bolt not spinning but still trying. Kind of like rapid loud clicking. I guess I should get a bigger gun now. Maybe Auto Zone would lend one out?
Seagull Management
360ft lbs isn't much torque for an impact gun. You want something in the 600+ range. My IR gun is 780ft lbs in reverse, makes most other 1/2" drive guns look like a joke.
Get the tool. Its only ~$25.
Then use a 6 pt. socket, 2 long 1/2 extensions (one for the tool) and 2 1/2" breaker bars with a cheater pipe. I use all craftsman and it has worked everytime.
Make sure to use a support under the head of the breaker to get square torque.
This is the non hex pulley tool I made out of angle iron for my car.
Powered By Garrett
11-04-2010 10:00 AM
