Remove Intake pipe from throttle body. Should engine die?
I'm trying to trouble shoot a rough idle problem. When i remove the intake piping fron the throttle body should the engine die? I don't think it should, but maybe i'm wrong. I also assume the throttle plate should be totally closed during idle right?
Thanks
Thanks
It'll run as long as there's not some sort of Mass Air Flow meter ahead of the throttle body. Hondas generally use a "speed/density" airflow metering system, so they'll run with an open-to-the-elements throttle plate.
muddmonky
Dec 22, 2012 05:36 PM
hillbillycivic
Nov 6, 2012 03:59 PM
Audi2Honda
Aug 19, 2002 06:11 PM
