remove gsr tranny
Old Sep 18, 2004 | 10:49 AM
fufu's Avatar
Default remove gsr tranny
does anyone know how to remove integra tranny at home? my spoon flywheel worn out and it make start the car hard (starter grind with spoon flywheel) i have to use another flywheel
i know the procedure to remove tranny, just unbolt all bolts,starter, axles..etc but the problem is remove the tranny, help please
anyway is the spoon flywheel fixable?
Old Sep 18, 2004 | 10:57 AM
acurasolution's Avatar
Default Re: remove gsr tranny (fufu)
you're almost there, just make sure your car is on jack stands and have enough clearance to pull out the tranny from under, what is the problem?
Old Sep 18, 2004 | 08:59 PM
porschekremer's Avatar
Default Re: remove gsr tranny (acurasolution)
i have had problems where the tranny sticks to the block, use a pry bar and a friend it'll come out might take a lil work. best bet is to replace the flywheel
Old Sep 18, 2004 | 09:59 PM
fufu's Avatar
my problem is the tranny is too heavy to drop and lift back up to put back on the block
Old Sep 19, 2004 | 01:55 AM
BuiltTurboCoupe's Avatar
get some muscles nah im playin maybe use a jack or somehting to help it down or lift it back up
Old Sep 19, 2004 | 09:07 AM
acy76's Avatar
Default Re: remove gsr tranny (BuiltTurboCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fufu &raquo;</TD></TR><TR><TD CLASS="quote">my problem is the tranny is too heavy to drop and lift back up to put back on the block</TD></TR></TABLE>
Use a jack for ease. The b-series transmission weighs about 80 lbs. dry.
Old Sep 19, 2004 | 11:08 AM
asubennett's Avatar
Default Re: remove gsr tranny (acy76)
I just get under the car while it is on jack stands and wiggle it off with my hands and lower it onto my chest/belly. Then I gently transfer it to the ground and slide it out. Seriously most 16 year olds can bench press at least 140lbs and this weighs a little over half that. You will have no problems.
blakacintegra
Jul 15, 2007 11:22 PM
rice a roni
11
Apr 26, 2006 05:10 PM
Rywire
Apr 20, 2004 03:55 PM
EKHappy
Dec 12, 2002 11:58 AM
gsr squirrel
Mar 29, 2002 07:52 PM
