CrVtec Turbo Cams
Old Jun 20, 2005 | 10:32 PM
91DroppedHatch's Avatar
Default CrVtec Turbo Cams
I just want to hear peoples opinions on which cams to get for the powerband of a crvtec, ive read other posts and searched but what ive come up with is that for boost the gsr/itr is good but it makes nice power at around 8-10krpm. But with the crvtec i know they cant really rev past 8k, so what cams do you all suppose people wit ls vtec and crvtec use? Just because of the shitty R/S ratio, cant really rev that high. Anyone please reply to this post for people who search for the same thing i was looking for.
Old Jun 21, 2005 | 08:28 AM
Chip's Avatar
Default Re: CrVtec Turbo Cams (91DroppedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91DroppedHatch &raquo;</TD></TR><TR><TD CLASS="quote">Just because of the shitty R/S ratio, cant really rev that high.</TD></TR></TABLE>
Tell all those guys with built LS/VTEC's that are making turbo power to 9000+ RPM's that they can't rev high because they have a barely worse rod/stroke ratio than the GSR's.
GSR/ITR cams are fine. If you're running a stock block run whatever cams came in your head. If you're running a built motor run ITR cams for more top end.
Old Jun 21, 2005 | 11:53 AM
Ok, so revving past 8k wouldnt really run down the motor? What all should I replace to keep the revving high still reliable? Valvetrain? Block work? Head Work? Also what should I set the rev limit at on the turbo crvtec?
MI4$DC5
Apr 22, 2006 06:37 PM
aznsins88
Nov 18, 2004 03:13 PM
igotyofire
Sep 10, 2003 04:31 PM
GOLDBERG
15
Aug 4, 2003 03:32 PM
JustVTEC
Sep 19, 2001 08:17 AM
