rear disc brake question?
Old Jan 21, 2009 | 07:07 AM
ramos2589's Avatar
Default rear disc brake question?
Which rear disc Set up will fit my 93 civic sedan dx
Old Jan 21, 2009 | 11:09 AM
bandit080000's Avatar
Default Re: rear disc brake question?
I think this will help you out.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/integra-rear-disc-conversion-eg-hatch-lots-pics-812062/ (how-to)
http://www.jdmcivic.com/forums/showthread.php?t=29225 (how-to and parts)
Old Jan 21, 2009 | 01:24 PM
ramos2589's Avatar
Originally Posted by bandit080000
How about the sedan because that info is for a hatch and 96 + civics
Old Jan 21, 2009 | 01:50 PM
The process is going to be the same. However, the parts you're going to need are off a 94-01 Integra. You'll need the lower control arms, trailing arms, and the brake assembly. Depending on what your budget is, I'd really recommend just buying a kit to do it. You can get kits for 200-350 that'll come with everything you need. You should also get a new master cylinder/brake booster and proportioning valve. Depending upon the age of the stuff you have, the sooner it's likely to fail, especially with the new configuration.
Old Jan 22, 2009 | 06:07 AM
92_civic's Avatar
sedan parts will work...any 92+ civic with rear disk...any 90+ teg, will work
em2Dima
Honda Civic (2001 - 2005)
Jan 27, 2012 11:48 AM
mikey1992
May 9, 2010 07:35 AM
meric0786
Mar 14, 2007 09:15 AM
spoon95eg
May 17, 2006 03:21 PM
mingbling96
May 6, 2006 09:55 PM
