Rear Brake Drums Help
Old Mar 19, 2004 | 06:16 PM
gabebauman's Avatar
Default Rear Brake Drums Help
I'm replacing the brake shoes on my 98 honda civic ex and I'm struggling on how to remove the drum to get at the shoes. Do I just tap on the drum with a hammer and pry on it?
Edit Done, thanks anyway.
Modified by gabebauman at 7:54 AM 3/20/2004
Old Mar 22, 2004 | 04:20 PM
sohc00's Avatar
Default Re: Rear Brake Drums Help (gabebauman)
1st remove the small plug that cover the adjustment hole at the rear of the backing plate. Once the hole is open, use a brake spoon to move the brake shoes from the drum. the shoes must be backed away each time the brakes are applied. this wearing will cause a ridge to be formed on the outer edge of the drum or the edge toward the backing plate. as the shoes are adjusted outward, they' ll be trapped behind this ridge and will keep the drum from being removed until the shoes are backed away.2nd use a large dead blow hammer and strike between the studs while rotating the drum. DON'T strike the outside or the rear of the drum it may damage it. Be patient, rotate,strike,rotate,strike,and sooner or later the drum will break free. I hope u can use my help. GOOD LUCK
Old Mar 23, 2004 | 07:07 AM
Cory man's Avatar
Default Re: Rear Brake Drums Help (sohc00)
One other thing you can do is using a bolt to "work" the drum off. There are 2 threaded holes on the drum surface that are used for this purpose. The bolts that hold the dist on work perfectly for this. HTH
Old Mar 23, 2004 | 11:26 AM
doublejz's Avatar
Default Re: Rear Brake Drums Help (Cory man)
use the 2 8mm holes in the drum, and run to bolts into them, and it'll pop right off
Old Mar 23, 2004 | 04:18 PM
Gsr_Hybrid_theory's Avatar
Default Re: Rear Brake Drums Help (doublejz)
just make sure you dont have the e-brake on
you can use the star wheel in the drum, (behind the drum) and loosen it untill itll come un-done... before you do this though, does the drum SPIN??? lol
Old Mar 23, 2004 | 05:21 PM
rubix777's Avatar
Default Re: Rear Brake Drums Help (Gsr_Hybrid_theory)
yeah I once had my e-brake one while I was trying to take the drum off.
get a rubber mallet and give it a few taps
Old Mar 23, 2004 | 05:38 PM
iwhichisme's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz &raquo;</TD></TR><TR><TD CLASS="quote">use the 2 8mm holes in the drum, and run to bolts into them, and it'll pop right off</TD></TR></TABLE>
exactly what youre suppossed to do. Really the only way to do it, unless ya wanna **** somethingup.
Old Mar 23, 2004 | 08:10 PM
gabebauman's Avatar
Default Re: Rear Brake Drums Help (iwhichisme)
Thanks for the help guys...I threaded bolts into the holes and they popped right off.
Old Mar 24, 2004 | 08:51 AM
doublejz's Avatar
I hate when people just beat the **** outta them until they come off
cheapo23
Jun 2, 2010 09:28 PM
joelmatt89
11
Mar 9, 2009 05:30 PM
MrDomino
May 15, 2008 03:42 PM
wavewuver
Sep 30, 2004 04:38 PM
