re-use bearings?
Old Jul 13, 2006 | 03:35 PM
crazy_hype's Avatar
Default re-use bearings?
I'm putting together a gsr motor that had 45k miles on it when before i started the build... long story short it was sitting around for 2yrs then decided to bring her back to life. I recently got the block honed and i was wondering if i NEED to use NEW main bearings, there is no damage to them and i don't want to replace them if i don't have to. However, i will be replacing the rod bearings because there is a light scratch in one of them.
can someone point me in the right direction?
do i need to worry about clearance if i re-use the bearings.
I also for got what bearing came from where can i put them where ever or do they have a specific place they each need to go?
Old Jul 13, 2006 | 04:18 PM
mmuller's Avatar
Mad Scientist
Default Re: re-use bearings? (crazy_hype)
if your going to re-use the bearings, they are color coded and they need to stay in the journal they came from along with their matching half.
i would still check clearances, oem is not optimal sometimes..
SwagNationEK9
Nov 13, 2013 02:47 PM
MeathooK
Jul 14, 2008 06:23 AM
eg:R
Sep 21, 2006 05:33 PM
Bambooseven
Oct 20, 2004 07:48 AM
badCRX
Feb 12, 2002 10:13 AM
