? About main cap bearings
Old Feb 11, 2002 | 12:00 PM
badCRX's Avatar
New User
Default ? About main cap bearings
I have a B20 that I am building up for my CRVTEC and as we all know those are relatively new motors. I am replace the rod bearings as I'm putting in Eagle rods. What about the main bearings? Any harm in putting the original ones back into place? I know I'm being cheap, but would it be fine? I would just assume I'd need the same colors as what I took out of the block to replace the main bearings with.
BTW: there is no unusual wear or tear on the bearings I pulled out.
Old Feb 12, 2002 | 07:22 AM
VTEC4GS's Avatar
Default Re: ? About main cap bearings (badCRX)
if low mileage, check also for scars ont he bearings or spots of heat stress if plenty replace them or at least the ones that are stressed.
but figure for $100 buks and you have the chance to change bearings, why wouldn;t you ? you wont get this chance again unless you take motor apart again.
Greg
Old Feb 12, 2002 | 08:30 AM
WAFFLES's Avatar
Default Re: ? About main cap bearings (vtec4gs)
like he said just check the bearings for stress marks and hot spots. The total bearing cost for all bearings is relatively cheap, so you might aswell spend the money. My total cost on bearings was somewhere around $200.
Old Feb 12, 2002 | 10:13 AM
Kataku2K3's Avatar
Default Re: ? About main cap bearings (WAFFLES)
I would just go with new bearings, why take the chance on ruining ur motor. If you do reuse the orginals do as everyone else has said and check them!
JaHnAbOi
12
Jun 22, 2006 11:00 PM
jman30513
Jul 10, 2004 02:37 PM
graphic
Apr 21, 2004 05:56 PM
jdmhatch94
May 19, 2002 12:27 PM
